Question about Proscan Televison & Video
How do i reset my proscan tv 26lb30q without a re mote an cant find the reset hole
Posted by Mary ellen Schultz on
2answers
2answers
I have my computer hooked up to my proscan 26LB30Q. The power will come on, but it only stays on for about 30 seconds. What do should I do to make it stay powered on?
How are you interfacing your computer to the tv? HDMI? RGB video cable?? Some tv's especially Vizio's will automatically turn off if it doesn't sense a video signal on the RGB input after about 30 seconds. Make sure your computer is putting out a video signal.
I bought a Proscan 26LB30Q TV. After connecting to the indoor digital antenna, no signal showed up on the screen. What could be wrong? Thanks.
MAKE SURE WHERE YOU HOOKED UP THE ANTENNA SAYS DIGITAL,,IF ITS NOT IT WANT WORK ON TOUR TV,, POEPLE THINK JUST CAUSE ITS A NEW FLAT SCREEN THAT IT DIGITAL,,, BUT A LOT OF THEM STILL ARE JUST ANALOG ANTENNA READY,,,,,THE ANTENNA JACK SHUOLD SAY EITHER ANALOG OR DIGITAL,,
2answers
4helpful
4answers
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
What remote do I buy for the Proscan LCD 26lb30q?
Try Ebay they have them the item number is 350167917823 just type that in the top where you would put in what you want to find.
4helpful
5answers
Looking for a wall mount that fits the ProScan 26LB30QD
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
The screen turns on hen off
Just try to reset;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Televison & Video Logo
Top Proscan Televison & Video Experts
Ekse
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
