Question about Samsung Televison & Video
Samsung tv remote code - Samsung Televison & Video
Posted by Nick Welford on
    Top Expert:
  • Samsung Master
  • 76,407 Answers
0382,0319,0271,0299:
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" of your device; that you want set-up code, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Mar 24, 2019
Need a code for Steren universal remote control for a samsung tv.
Remote Control Codes For Samsung TVs Codes For Universal Remotes
Try these common UNIVERSAL Samsung 4 digit remote control codes first:
0019
0618
0644
0056
0060
0587
0037
0178
0030
0556
0009
0702
0774
0093
0217
0448
0747
0482
0370
0264
0329
0090
0032
0216
0290
0154
0150
0092
0072
0179
0208
0519
0156
0163
0625
0226
0812
0817
0821
1060
Philips Universal Remote:
Samsung TV codes: 0112, 0309, 0209, 0512, 0302, 0502, 0002,
0102, 0110, 0818, 0895, 0437, 0802, 0103, 0609, 0012, 0212
One-For-All Universal Remote:
Samsung TV codes: 0587, 0178, 0093, 0060, 0030, 0019, 0056
GE Universal RemoteSamsung TV codes: 0105, 007,7 0076, 0109, 0007, 0009, 0004,
0005, 0085, 0172, 0942, 0358, 0012, 0015, 0080, 0104, 0106
RCA Universal RemoteSamsung TV 4 digit codes: 1004, 1009, 1012, 1013, 1014, 1015, 1025, 1046, 1056,
1065, 1069, 1078, 1083, 1102, 1103, 1104, 1123, 1124, 1194, 1205, 1207
RCA Universal RemoteSamsung TV 5 digit codes: 10812, 10054, 10060, 10702, 10178, 10030, 10056, 10650, 10766, 10814, 11060
Innovage Jumbo Remote Samsung codes:
004, 005, 009, 015, 104, 105,106, 109, 172
Aug 08, 2018 | Samsung Televison & Video
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Feb 05, 2016 | Samsung 50 in. Plasma TV
Codes
How to program a Samsung AK59-00104K remote control
How to program a Samsung AK59-00104K remote with codes:
  1. Turn on the TV.
  2. Point the remote at the TV.
  3. Hold the "TV POWER" button while entering a two digit code.
  4. Release the "TV POWER" button.
If you enter the correct two numbers, the TV should switch off.
TIP: Start entering the remote codes at 00, then 01, then 02, then 03, etc...
TIP: Once you find the correct code, write it down somewhere you can find it next year!
Codes:
Apr 13, 2014 | Samsung Remote Control Ak59-00104k For...
I have a samsung hd841 dvd player. i need tv codes so i can program the samsung remote control to be able to use tv with same remote. thanx
Unless your Samsung remote is programmable, you have this backwards. If your Emerson TV remote is programmable, you need to use it to control both your TV and your Samsung DVD player
Dec 26, 2012 | Samsung DVD-HD841 DVD Player
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
I need help programing my rca remote to a samsung television
Hi
Ideally I need you to clarify a few details on your exact RCA remote model and number and also whether this is a Samsung TV or other unit like a DVD etc.... that you wish to program
However assuming it is a Samsung TV here is a list of the common RCA codes for this TV. You will need to go through each one individually until you find one that works.
Code 1004 for Samsung TV Code 1005 for Samsung TV Code 1006 for Samsung TV Code 1012 for Samsung TV Code 1013 for Samsung TV Code 1015 for Samsung TV Code 1017 for Samsung TV Code 1019 for Samsung TV Code 1082 for Samsung TV Code 1104 for Samsung TV Code 1105 for Samsung TV Code 1106 for Samsung TV Code 1171 for Samsung TV Code 1172 for Samsung TV
Hope this helps. If so please do rate my answer.
Otherwise please post up additional details as outlined and I will see what I can find.
Many Thanks.
Sep 06, 2009 | RCA ACC-RCAURC Remote Control
Need control code, to operate dvd samsung
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can try.codes from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
May 04, 2009 | Samsung TV Remote Control
Remote codes
http://www.oneforall.com
Hope this helps.
Len
Feb 27, 2009 | Televison & Video
Televison & Video Logo
120 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
