Question about Watches
MU1248 Disney Mickey Mouse Watch What is the current value of a timepiece in great condition?
Collection Name-Lorus Part Number-MU1248 Display Type-Analog Clasp-Fold over Band Material-Stainless Steel Band Color-White Dial color-White Movement-Analog quartz Dimensions:3.7 x 3.3 x 2.1" Weight:4.8 ounces
Posted by Ken Smallwood on
STEVE yes that one
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Watches Master
  • 35,534 Answers
We dont value things on this website
Posted on Feb 24, 2019
2 Related Answers
Anonymous
  • 43 Answers
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Posted on Jan 05, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 04, 2009
I have a mickey mouse watch and I can't set it. It is running. It is a Lorus with the numbers vg91 6000 Z0 call 256-757-1533 Thanks
If any analog watch will not set and it is running, most likely the set wheel (gear) of the movement is damaged and the entire movement must be replaced. The wheel alone is not possible to replace.
I recommend visiting or contacting your local Certified Master Horologist to attain what is usually a free estimate or quote on the replacement of the movement.
Feb 23, 2011 | Disney Watches
Need to replace battery of lorus mickey mouse pocket watch
Try to find a watch repair shop (sometimes called clock & watch shops). Also, many jewelers replace batteries and do watch repair.
Jan 13, 2011 | Lorus Watches
I just bought an older Lorus Disney Mickey Mouse Musical watch V422-0010 with a box behind this number thia square was around the letters ZO. I cannot get the watch to work. It says, "After installing...
There is no CR920 3 volt battery and especially will not work for any Lorus watch. There is the SR920SW and SR920W series 1.55 volt silver alkaline cell.. 9 mm diameter x 2.0 mm height is an impossible size for this old Lorus watch.
Jan 02, 2011 | Disney Lorus Rare Musical R2306AX Watch
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
Dec 17, 2010 | Disney Lorus Out of Production Collectible...
I have a minnie mouse that was made in 1928! does any one no howmuch itz worth its called classic mickey!! please
mcdevito75 here, hello miss d, the first Mickey watch Disney came out with was in 1933, Mickey was invented in 1928, if this is a picture of your Mickey above, then it wa made in the early 1980"s. If it's working very well it could be worth a collector value of approx. $30.00 --$50.00
Dec 08, 2009 | Disney Since 1928 Classic Mickey Mouse...
I have a Lorus NX11A multifunction watch and have no manual. I have been on the Lorus website but it might as well be written in Japanese
mcdevito75 here, I would imagine this is a Mickey Mouse Lorus watch by the picture supplied. If it Has DAY / DATE function, here"s what to do, --- To set the DAY, pull the stem out to set, keep turning the hads till you rech the day, then push in the stem. To Change the DATE 9 number) slip your fingernail just under the stem and lift it to it"s first position (notch) this should allow you to change the DATE (number) without haveing to turn the hands so many times.
Jun 24, 2009 | Disney Lorus Out of Production Collectible...
Watches Logo
53 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
