Inglis front loader, model #IFW7300WW01. Why doesn't it work?
It stopped working with a load of clothes in it and I had to manually open the door. I replaced the door latch sensor.
Posted by SCOTT SHKOPICH on
5 Related Answers
Anonymous
  • 97 Answers
SOURCE: Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
Posted on Nov 07, 2007
Anonymous
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
Anonymous
  • 1028 Answers
SOURCE: front door buzzing Frigidaire front loading washer
replace entire door lock assembly ..remove spring holding the door boot in place and roll boot back ..unless you have the one where the seal is glued then carefully slide knife under edge to cut through glue take the screws from lock and pull through opening remove wires and install new lock ..if noise is only issue use till it blows then replace
Posted on Jul 31, 2008
Anonymous
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: sumsung J845 front load washing machine cannot open the door
What you need is a Samsung service repair manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 03, 2010
Testimonial: "Thank you for the manual, it helps me take off the top cover, but I am still in the same problem. But thank you all the same"
Hello! My Kenmore washer door will not open. It's completely locked and will not budge no matter what I've tried. I have a load of cloths in there as well. When I turned the power on detergent and cloths...
Unplug the washer for AT LEAST 30 minutes to reset the Central Control Unit (CCU). If the door still remains locked after a CCU reset, you can still open the door by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
NOTE: The "Fdl" and Fdu" fault codes are for older models of your washer, but the principle of accessing and releasing the door latch is still the same.
If your error code still persists, you may have to replace the door latch. Just follow the guidance in the link below:
http://www.fixya.com/support/r1484196-f29_error_code_whirlpool_duet_kenmore
Dec 11, 2010 | Kenmore Elite 45986 Front Load Washer
Whirpool dryer model wed9400swo the dryer door pops open
This usually occurs when the load is too large, causing the cloths to push the door open. If this is not the case, you should replace the door latch mechanism, which is what keeps the door closed.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 14, 2010 | Whirlpool ET8CHEXSQ Dryer
Machine thinks door is open and won't run a cycle!!!!!!!!!!!!!!!!
There is a catch latch on your dryer door and that may be softening up when the dryer gets warm and the clothes tumbling against the door is enough to push the door out to the point that it thinks it is open. Try this exersize... The next time you wash clothes place a chair sideways against the doon with your clothes basket on it and see it it completes the cycle If it does then your door latch and actuating arm / post need replaced.
Jan 13, 2010 | Dryers
I cant open the door
The door lock solenoid may be stuck. If the unit has a load in it, it could have a piece of clothing stuck in the door latch or too full of a load applying pressure on the door. Try to push the door inward with slight pressure and then pull out. If that does not work try unplugging the unit and then opening the door. The only other option is to remove the panels and manually release the door catch.
Sep 10, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I have a two-year old Frigidaire GLTF2940FSO front loader washer that has stopped in the middle of a load leaving water in the drum and will produce a buzzing sound no matter what cycle you put it on. We...
did you try unplugging it and plugging it back in to see if you can get it to reset? Would it buzz when you try to drain it? Does the door latch lock when it goes into the wash cycle? Usually the door latch locks when it goes into the wash cycle and stays locked. So it filled up, the door latch should lock, then should go into wash cycle. Then you said few minutes later it stops. How did you get the door open? reason i ask is Usually i would see the clothes get stuck inside the washer because the door latch is still locked when it stops. Was the door unlocked when it stoped. If so maybe something going on with the communication from the board to the door latch maybe. Did you try operatin the drain?
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
My maytag neptune front load washer won't unlock. I may have to replace the wax motor per so many other blogs. I may be able to get to it in two days. Meanwhile, I have expensive clothes locked inside my...
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
Apr 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
The machine runs until the spin cycle then stops
That means that you need to have the door latch replaced, a bad door sensor is preventing the washer from spinning.
Try first unjamming the latch with a stick, like a pencil for example.
If that does not work, replace the door latch.
Mar 30, 2009 | Whirlpool AWM8163 Front Load Washer
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Latch stuck after each load
Hello bittoner
Welcome
You said,The latch remains in the door closed position after each load. I can manually reset it by taking the cover off and it works fine until after it runs a cycle and I open the door again. Is this a latch problem or a electronics problem. Note, I have replaced the latch assembly about a year ago for a different reason
Try to turn off the breaker for the washer for 5 minutes and see if the system reset.
If not the electronic door switch sensor is bad
Let me no how it goes.
Huuum
Please remember to leave a rating!
Oct 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door latch is in "LOCKED" position however the door is open!
es posible q tengas unproblema con el sensor de apertura de la puerta, tal vez este pegado o le cayera h2o, por eso el microcontrolador interpreta q la puerta sigue abierta y por eso no realiza la rutina de lavado, debes buscar el plano, determinar la ubicacion del sensor y verificar su estado.
Jul 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
