Question about Ariston Technologies Washing Machines
HOw do I unlock my ariston washing machine - Ariston Technologies Washing Machines
Posted by Cheryl February on
Andrew Taylor
    Top Expert:
  • Ariston Tech... Master
  • 32,974 Answers
If it is a child lock, normally by pressing and holding the Child Lock Button. Sometimes it requires two buttons, from Off, press and hold the On button and the Child Lock button for 6 seconds.
For other lock problems, see the videos
https://www.google.com/search?q=unlock+my+ariston+washing+machine
Posted on Feb 24, 2019
5 Related Answers
Anonymous
SOURCE: ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Posted on Jun 13, 2008
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: my ariston washing machine door not locking
I recommend replacing the door latch. It is a fairly common problem. You can get one at repairclinic.com or partselect.com
Posted on Jan 02, 2010
Anonymous
  • 41 Answers
SOURCE: We have an Ariston A1636S Washing Machine. When
COULD BE SOMETHING IN THE DRUM UNDER THE CROME PIECE THAT THE CLOTHES GO ONE
Posted on Jan 09, 2010
Anonymous
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Posted on Jan 27, 2010
Why won't my Splendid Ariston washer spin during a regular wash cycle?
Remove the kick plate from the front of the machine and you will find a removable screw-in bung. Put something underneath to catch water. When you remove it, you will find a plastic toothpick in there which is jamming the pump impeller. The safety feature stops the machine spinning if the pump is not working.
Splendid Ariston Google Search
Jan 03, 2017 | Washing Machines
Ariston dishwasher lkf 720 has a problem on/off, washing and end indicator lights are flashing
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes: the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
After you determine which the alarm code appeared we will able specifically to help you.
Dado
Sep 13, 2014 | Ariston Technologies Ariston AWD12 Front...
How to unlock the door
Lamp M flashes slowly when the appliance is switched on and
a waiting instructions and at the end of a cycle, indicating that the door can be opened. It flashes quickly when the door should not be opened. A steady light means the appliance has accepted the selected programme.
24967037-ineink0kisfnom0atbkujjcx-3-1.jpg If you correctly use the appliance then defective can be interlock, wiring or board.
If the door is constantly locked then you can access to interlock by removing the top cover of washing machine.
Dado
Aug 17, 2014 | Ariston Technologies Ariston AWD12 Front...
Do you have a manual foe AV61 ariston washing machine please
Manual for this machine can be found at:
http://www.instructionsmanuals.com/u2/pdf/lavadora/Ariston-AV61-en.pdf
Jan 30, 2010 | Ariston Technologies Washing Machines
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
My ariston washing machine door not locking
Jan 02, 2010 | Ariston Technologies AWD121WH
Dec 30, 2009 | Ariston Technologies Washing Machines
Ariston 6kg washing machine
Oct 07, 2007 | Ariston Technologies AWD 121
Washing Machines Logo
90 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Eric Taylor
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
