Question about Maytag Refrigerators
Where is the water filter on a Maytag MBR2256KES refrigerator?
Posted by Keith Gardner on
Piotr Pachkaev
    Master:
  • Maytag Master
  • 304 Answers
Hi! Please check the manual. There should be info or a contact of their customer support. https://manualsbrain.com/en/manuals/1401540/?page=17
Posted on Feb 28, 2019
5 Related Answers
Anonymous
  • 89 Answers
SOURCE: Water leaking from my maytag
Where is it leaking from? It could be either a clogged drain or perhaps a water valve. Give me more details and perhaps and help a little more. Also, There is a few details on leaky refrigerators at:
http://www.houstongofarappliancerepair.com/Refrigerator.html
Thanks and goodluck,
Brian
Posted on Jul 14, 2008
jvernice
Joseph Vernice
  • 63 Answers
SOURCE: bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Posted on Jul 29, 2009
Anonymous
  • 47 Answers
SOURCE: Maytag refrigerator water dispenser not working
you may have dislodged a sensor or perhaps you may have blocked your water line somehow... im not sure about this specific model, but just try having a look at what you did and see if there are sensors around there.. and make sure u havent dropped anything in there wich may have clogged the lines... lets hope its not your solenoid that has gone, sounds unlikely though you never know
Posted on Nov 11, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: Maytag refrigerator mbr2256kes leaks water about
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Posted on Nov 27, 2009
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: need to know which water filter to get?
You can buy the filter on link below.
http://buyitnow64.stores.yahoo.net/maukpuiirewa.html
Please rate 4 thumbs for the free answer
Posted on Mar 14, 2010
Freezer not working
Check the help links shown below :----Refrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html-----------Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This willhelp.
Thanks.
Feb 10, 2012 | Maytag MBR2256KES / MBL2256KES
I have a Maytag bottom freezer refrigerator w/automatic ice maker. The ice has terrible odor and taste. I do not have owner's manual and cannot locate a filter. i believe the fridge is about 3 years...
Searching the parts breakdown for your model number i do not see a listing for a water filter so i suppose it doesn't have a built in one. If it did have one it would be on the right hand corner of the ceiling of the fresh food compartment.
This link is for a pdf version of the owners manual https://www.maytag.com/digitalassets/MLPDF/User%20Instructions%20-%20W10208789A.pdf
Gene
Aug 05, 2011 | Maytag Refrigerators
We are trying to replace the ice maker filter on a Maytag mf2557hes. Where is it located? Does this Maytag Refrigerator have a filter?
Maytag brand water filter removal and replacement:
refrigerator_maytag-filter.jpg Removing and replacing a water filter
There are two different types of Maytag brand water filters. Each one is removed in a different manner, depending entirely on where it is located in your refrigerator. There are two main locations. Select your filter location from the options below for specific removal and replacement directions.
  1. The upper right corner of the refrigerator compartment.
  2. In the center of the ceiling of the refrigerator compartment.
Jun 12, 2011 | Maytag MFF2557HES Stainless Steel French...
Mbr2256kes freezer door start frising
Check for cracks around inside of door. COld refrigerated air may be leaking into door and freezing the outer door skin.
Nov 08, 2010 | Maytag Refrigerators
I have a Maytag Refrigerator Bottom freezerMBR2556KES2 with a left hand opening can i change the opening to open from the right? gary
it doesn't appear that this is possible with this unit, typically anymore you can't change the doors on refigerators as there are too many services (ice, water, freon) going through the door, and yours has a permanently attach tag at the top right and there are no holes on the other side of the door for the handle. some would think that you could turn the door over and that would put the handle on the other side, but i am betting that it will not work
Jun 15, 2010 | Maytag MBR2256KES / MBL2256KES
Bottom freezer - Refrigerator top not cooling- All vents from freezer open , no food in the way. Is there a fan ?
Yes there is and it is located in the base panel of the fridge. Look for a set of slotted vents in the inside of the fridge and the fan is located behind those slots. This fan uses the freezer temp to control the fridge temp.
Good luck hope this helped you some
Dave
Jan 29, 2010 | Maytag MBR2256KES / MBL2256KES
I would liek to know how thick the doors are on a maytag fridge.
Removing the doors will get you 2 inches. Look at the hinges, the one on top of the top door has screws to remove and the bottom of the top door fits onto a pin. Similar for the bottom door.
Nov 29, 2009 | Maytag MBR2256KES / MBL2256KES
Maytag refrigerator mbr2256kes leaks water about every 36 hours. It originates underneath, midway back and a little to the left (when looking at it).
Nov 27, 2009 | Maytag MBR2256KES / MBL2256KES
Water leaking from my maytag mbr2256kes
Brian
Jul 14, 2008 | Maytag Refrigerators
Refrigerators Logo
140 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
