Question about OKI Office Equipment & Supplies
How to reset image drum replace560,563, For oki mc362
I have printer showing message error code 560,563how can i hide this message without replace image drum ?
Posted by cpu computer on
5 Related Answers
Anonymous
  • 31 Answers
SOURCE: On Oki C5600 printer with error message
Try this procedure, don't know if it will work on your models.
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
Posted on Apr 12, 2009
alexeynayko
  • 73 Answers
SOURCE: How do you rest an OKI c3530 image drum
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Posted on Oct 07, 2009
Testimonial: "Great fast response."
Anonymous
SOURCE: reset drum
I think this machine does not have a reset option instead you can reset manually.All you have to do is on the right side of drum unit there exist a white + type notch,rotate it clockwise till it allows.Put back drum unit into machine.Switch on and see replace drum and supplies message will disappear.In my case it worked.Hope this is the best solution.All the best
Posted on Oct 26, 2009
Anonymous
SOURCE: resetting image drum after replacing for oki b4600
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE
Posted on Oct 30, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
  • Power on printer while holding both the + & - buttons simultaneously; release when “OKIUSER” is displayed.
  • Press either the + or – button until “ENGINE DIAG MODE” is displayed; press the Enter button and “DIAGNOSTIC MODE xx.xx.xx” will be displayed.
  • Press and hold both the - & On-line buttons simultaneously until “ENG DIAG LEVEL2” is displayed.
  • Press either the + or – button until “CONSUMABLE COUNTER SET” is displayed, press the Enter button; you are now in the menu to set various consumables.
  • Press either the + or – buttons to scroll through the various consumables, at the desired consumable press the Enter button and the last digit of the count will start flashing.
  • Press the Cancel button to decrease the digit amount or press the On-line button to increase the digit amount; press the + or – buttons to move along individual digits in the count.
  • Once the count is at the level you desire, press and hold the On-line, Cancel, & Back buttons simultaneously until the “*” reappears next to the count; consumable’s count are reseted to the number you specified.
  • Press the + or – buttons to move to the next consumable and repeat at step 5.
  • Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, you can use the Back, +, & - buttons to exit through the menus
  • until “INITIALIZING” is displayed.
Posted on Jan 30, 2010
The Samsung Printer M-2876ND is showing an error replace imaging unit. It has already printed 9000 units, so i guess the life of the unit is over. Now, i want to know if the same will work in case i j
Dear Ankit
you can replace the complete drum cart. or replace the CRUM (drum chip) of the drum cart. no need to replace the drum it can goes up to another 9000 a4 pgs.
Thanks.
Jan 12, 2015 | Samsung Office Equipment & Supplies
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
Dear Sir, Our Scanner was showing to change magenda toner and we change with new one, but after end of the process it is showing the error code of E000020-81, even after shutdown 3 times. What else I can...
The error code your gettting E000020 is a drum code (imaging unit). You however do not have the complete digits after the E000020-????. Those digits define which drum needs to be replaced. You don't need to go into service mode to clear the error. You only need to buy the correct drum and put it in with the power off. Once it is replaced and the machine is turned on it will register and clear its internal error code. To help, here is what the ending codes mean. The xx's have further meaning but in most cases all roads lead to the same result (replace drum imaging unit).
-01xx yellow (Y)
-02xx magenta (M)
-03xx cyan (C)
-04xx black (K)
Jun 25, 2011 | Canon imageRUNNER C3200 Copier
What is error message 091-935?
Imaging Drum
091-935
Replace
Imaging Drum
The imaging drum needs to be replaced.
Replace the imaging drum.
See "Replacing the Imaging Drums"
Dec 18, 2010 | Dell 3010cn Laser Printer
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
K image drum
The drum and toner cartridge are two separate items. You need to replace the drum.
May 26, 2010 | OKI C5150n Led Printer
Error message replace drum for printer hp laserjet
pristonero, there is no "main" button. what are you talking about?
Oct 20, 2009 | HP LaserJet 2840 All-In-One Printer
Panel shows error code Cof24
(Automatic Image density Correction) basicly this sensor looks at the drum and determines thew drums ability to hold toner and image. The sensor could have toner spilled on it or the drum needs to be replaced or the senor has gone bad
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 29, 2009 | Minolta EP1030/1030F CS/PRO Copier
Error message "engine firmware" code 72
Most likley the problem is a faulty Imaging unit. The chip on the unit has failed. You can try reseating the Imaging Unit and if that doesn't work replace it.
Here are the other listed causes.
Cause:
Corrupted NVRAM Possible Causes are Imaging Unit, Fuser, EEprom Board or PE/MCU Board
Feb 12, 2008 | Xerox Phaser 6200N Laser Printer
Canon Image Runner C3200 GPR 11 Drum Units
error code eo-20 on canon pc740 without replacing drum/toner unit
Nov 05, 2007 | Office Equipment & Supplies
567 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
