Question about Compaq Computers & Internet
I have an old Compaq pressroom SR 1030NX and it had win7but when factory reset it won't boot . I tried reinstalling Win7 but it crashed. Now I can't get passed logo. Im trying to boot with usb but won't work even though I put it 1st in boot sequence. HELP!!
Posted by Ian Hellson on
Andrew Taylor
    Top Expert:
  • Compaq Master
  • 32,389 Answers
I am pretty sure you can't boot an OS from a USB. Burn the install media to a disc or put it on a spare partition. USB boot is for anti-virus or PC Diagnostic Tools.
Posted on Feb 23, 2019
5 Related Answers
Anonymous
SOURCE: boot sequence problem
bios satup key
Posted on Jan 14, 2008
Anonymous
SOURCE: Fails to start - Logo is showing
I experienced the same problem after a week.
The only way to reset the player after freezing was to remove the battery. However starting up again resulted immediately again in freezing of the player (presenting logo, without any further action).
After having removed the battery and not turning the player on again, I inserted the player into the PC USB slot. The PC recognized the player as a memory stick only. (inserting the player in frozen condition did not result in recognition).
Using the right mouse button, I selected windows formatting and formatted the player (select FAT32 file system).
Everything is removed including the drivers for the MP3 player. Now the player is officially downgraded to a memory stick.
The driver for the player was still installed, but it did not recognize any MP3 file, which was actually stored in the memory (visible and playable via windows media player).
I downloaded from www.trekstor.de the driver and tools download and installed it on my PC.(http://www.trekstor.de/en/service/downloads.php?produktgruppe=5&produkt=83&sprache=none)
After installation an option becomes available via the start menu for "firmware update".
Upon selection a toggle for "formatting" is available.
Selection of formatting results in cleaning up the player and reinstallation of the MP3 player software.
The installed firmware version 2.620.573 is degraded to version 2.620.572, but I don't mind, since the sound volume is improved, while the player functions fine.
So therefore I would advice anyone to follow these steps to enjoy the player more ;-)
Posted on Mar 13, 2009
Anonymous
  • 66 Answers
SOURCE: hp compaq dc 7600
When you boot your computer, you need to hit the key to get you into the bios setup. F10, F2 or Del keys are the usual ones.
Once into the bios, change the boot order to make the CD drive first, and then you will boot right to the CD.
Note, you will also have to hit a key when it starts to boot, it will say, hit a key to boot from CD.
If you miss the key to get into the bios, you have to start over again. Sometimes you have to hit the enter bios key over and over to get in there.
Posted on Mar 26, 2009
Anonymous
  • 8 Answers
SOURCE: Not Printing. Reinstalled the software, reset printer to factory
If you are running Leopard, reset the printing system by control-clicking in the list of printers in the Print & Fax preference window. Then reinstall the drivers.
Apple Menu > System Preferences > Print & Fax. Control Click in the left area which shows the list of printers, and choose "reset the printing system"
macs2u
Posted on Aug 12, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: PXE-E61 Media Test Failure Check Cable on compaq presario 2100
A PXE-61 error message is most likely a faulty hard disk.
Try reseating the hard drive first and if you still get this error message again then you need to replace the hard disk.
To boot up with the CD you maybe able to press the F12 function key when you power up the laptop, this will bring up the a menu option to select an alternate boot device. If this option is not available then go into the BIOS configuration and change the bootup order and make the CD as the first boot device and the hard disk as the second device. You can can it back later.
Posted on Sep 14, 2009
Comapq 510 crashes in win 7
carefuully and quckly wach you compuer when it boots and press the right f something key i have a hard tiem doing this too there less then a 2 second window
its gonna say a coupla options befor it acutaly starts loading the win 7, so you gotta be on your toes,
i dont dont remember what 7 says cause me and my 7 have how shall it aherm eparted im back on good ol xp
so any ways it's imperitive that you press the on that getts you to bios
normall you you just dont mess with bios but sometimes you simply must now is one of those times alls you ahve to do is put the lan wifi switch on in bios and violins you is up and runnin on the internets in no time fliat
bye bye
[email protected],com
Jun 15, 2013 | Compaq DECbridge 510 (defebad)
I have a compaq presario sr 1103 wm running on xp. I have had this pc for about 8 years, I do not have the revovery disk. I want to restore this pc back to orininal factory settings. how do i make this...
You can only restore to factory settings if there is a recovery console stored on a hidden partition
(try CTRL+F11) at start-up--otherwise need to reinstall the OS with a disk.
Dec 28, 2010 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
BIOS Lock preventing reload on Tiny PC
For that you need to RESET your bios settings to factory defaults.
Open cpu cabinet cover and pull cmos cell from motherboard for 10 minutes then all settings goes to defaults.
You can also reset settings with jumper it is near cmos cell it has 3 pins 1-2-3 put jumper in 2-3 position then power up the computer then all settings defaults.
Then if you want to boot your computer with disk then when you power up the computer press F1 or F2 or del key to enter in bios then go to boot menu and set first boot device as cd/dvd rom then save settings and exit.
Then it boot with your disk.Then follow the procedure on screen then you can reinstall your windows or recover old windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 13, 2010 | Computers & Internet
The previous hard driver was bad. I replaced it with a new hard drive. I used the Toshiba default factory setting to reinstall the softeware and now my laptop will not boot up.
Toshiba default factory setting can only restor your software if you have backup copy on New Harddrive.
As your old Harddrive crashed, you have to reinstall Operating system and requie software on new Harddrive.
Mar 09, 2010 | Toshiba Satellite P205D-S7454 Notebook
My widows (compaq)98 have crashed or got deleted.
Corrupt hard drive or boot table. Only solution is to attempt a reinstall with the original 98 disc.
Dec 20, 2009 | Microsoft Windows 98 for PC
OPERATING SYSTEM NOT FOUND MESSAGE
HI,
This can be an issue with the hard drive..
Go to bios by tapping F10 while the system boots > go to diagnostics and select hdd self test.
If it given an error "No IDE device found" then try reseating the hard drive. i.e. take it out and put it back in.
Otherwise try changing the boot order by going to advance / system configuration > select boot order > select the hdd and pess F6 till it goes to the top. Press F10 to save and exit.
Hope this helps..
Regards,
Anup
Apr 08, 2009 | Compaq Presario 700US Notebook
Crashing a compaq nx7010 o n purpose
You can directly do this with setup boot diskette (came with your laptop).
There you'll find the option to format and do a clean installation of windows.
For this, you need to configure CD-ROM as your first boot device and follow on-screen instructions after booting.(i am assuming that you've done the formatting and clean setup before)
Thanks.
Mar 17, 2009 | HP Compaq nx7010 Notebook
Screen says boot error
Try to reset the device. Reset it to original factory settings and try again.
Sep 26, 2008 | Sony Walkman NWZ-B105F MP3 Player
ASUS A7V8X motherboard
its not exact. its not made for compaq by asus so bios has to be used from asus site not compaq.
it wil fit in it and run but drivers and support is no longer a compaq
Aug 17, 2008 | ASUS A7V8X Motherboard
Computers & Internet Logo
165 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
