I keep getting a Protector reding on my screen and it will not let me do anything. What do I do to fix this?
Try disconnecting everything (speakers cables, signal cables, all other units) except the power cord, then turn the unit on, if the protector message persists, then the fault is in the reciever.
If this is the case, you should check the speaker and signal connectors for any damage, shorts or loose solder contacts, also check the unit for any shorted or broken wires, loose wire connections, bad solder contacts on connector pins, bad solder contacts on ANY other components (give some extra attention to the components that tend to warm up while they operate, like main power amp transistors / ICs, voltage regulators, power resistors, diodes, also coils, capacitors, etc). Any loose solder connections should be resoldered.
If there's no message when you've disconnected the outside equipment, you have either a bad speaker, a bad speaker cable, a bad signal interconnection cable, or a fault in any of the units that were connected to the reciever. You can find which one is the cause by turning the reciever off, then connecting one cable or unit, turning the reciever on again, see if there's a message, if there's none, turn it off again, connect the next unit / cable and so on, until you get the protector message. The cable or unit that will make the message appear is most probably the cause for the trouble (there might be loose solder connections on other units' cable connectors or other components). When you plug and unplug the cables many times, with time this will loosen the solder connection on the pins inside the unit, so these need to be resoldered.
Hope you can find out what it is.
regards
3rq8 (Triarcuate)
