Question about Cooking
Con air cwt 200 is a butane warming plate. What butane refill is needed
Posted by John Howarth on
4 Related Answers
Wayne Tolonen
  • 394 Answers
SOURCE: air con blows warm air
A couple of things will cause this problem. The first is making sure the compressor has voltage (blown fuse). The most common is it is low on refrigerant. Freon 134a. Good Luck.
Posted on Apr 26, 2010
oneStan
oneStan
  • 439 Answers
SOURCE: Hi, The air con in my 2003 Audi A6 1.9 tdi 130 is blowing warm air the air con rad is fully gassed and all fuses are ok . Thanks in advance for any advice on how to fix
The only other thing then would be if the compressor is turning, engaging, and the cooling fan working properly. You should either be able to see the compressor clutch engage, as the switch is energized, or at least hear it click loudly when the switch is energized. If it is not, then there are sensors for the low pressure/high pressure line to tell the compressor when to function, that also have to be checked.
As the engine runs with the compressor turning, one line should be hot/warm, the othe,r (larger diameter hose) should be cool/cold, if the system is working properly.
If the compressor is turning when you have the A/C turned on, then see if the cooling fan is running as well. It must run to remove the heat and cause the process to function properly.
Posted on Mar 28, 2012
kenny_econom
kenny economy
  • 58 Answers
SOURCE: butane leaks out at fill valve of butane micro torch
turn the screw to the right.
Posted on Nov 26, 2012
Brennan hebert
SOURCE: how to fix jammed refill valve on butane lighter
I am in the Same situation, I have completely removed the tank, and dismantled it, what is clogging it is the gunk left behind by cheap butane, I keep researching but no one has a solvent or liquid that will dissolve the gunk, I am considering vinegar but I think it will ruin the seals, Please tell me if you know any way to disolve the green oil gunk.
Posted on Jul 10, 2013
I have a model 35002 triple torch Colibri gear lighter and I need instructions on how to refill it with butane.
There is a small nipple on the bottom of the lighter. That is where you put the canister on to refill.
Dec 12, 2015 | Colibri Watches
Can i refill conair butane cartridge
There are two videos on YouTube on the subject. Before you start, remember neither the Fire Marshal nor your insurance company will be happy with you when you burn the house down.
How To Refill Thermacell Butane Cartridges Cheap Save Money
How to refill thermacell butane cartridge the easy way Save money
Feb 27, 2015 | Conair Instant Heat Curling Iron, Model...
How do I refill a "Ready Aim Fire" propane lighter?
There should be a small fitting/nozzle on the bottom of the lighter. If you pick up a can of compressed butane (big brand is Ronson) you can refill it with that. All you have to do is position the can nozzle onto the lighter fitting and an press for about 10 seconds. It will then be full. Lighters won't always work right away while it is cold. Warm it up in your hands if you need it right away.
May 19, 2014 | Computers & Internet
Weller Pyropen WPA2 extinguishes itself after a few minutes.
Gas (condensation really) may be freezing and constricting flow. Try warming the tip a bit with a hair dryer see if it goes longer.
Jan 11, 2014 | Weller WPA2 Pyropen Professional Self...
How to fix jammed refill valve on butane lighter
Wouldnt suggest messing with it. can be dangerous,may loose a finger or worse...buy a new one.......
Aug 15, 2012 | Cars & Trucks
Air con fan works but no cool air the compressor doesn't appear to start
It may need regassing, air con runs out after a while as its 2005 it most likely needs to be regassed/refilled!
Jan 14, 2010 | 2005 Ford Futura
Colibri wellington ligther refilling
Turn the flame height adjuster on the bottom of the lighter to the lowest setting by turning it clockwise.
There are three different kinds of flame height adjusters: hand, thumbnail and screwdriver. If you have a screwdriver flame height adjuster, you will need to use a slotted screwdriver to turn the adjuster.
Hold the lighter away from your face. On the bottom of the lighter there is a refill valve. Push down on the valve with a screwdriver to let the compressed air out. You will know all the air has escaped when you no longer hear a hissing sound.
Turn the lighter upside down, so the flame end is facing the ground. Insert the stem of the clean butane fuel refill at 45 psi pressure into the refill valve and press down.
Hold the refill can in this position for five seconds.
Remove the stem of the refill can from the refill valve, and tap down on the valve once with a screwdriver to force out the remaining air.
Wait three to four minutes to let the gas reach room temperature before attempting to use the lighter again.
Turn the flame adjuster counterclockwise when you are ready to use the lighter again.
good luck
Jan 05, 2018 | Euro-Pro GPS
Dunill lighter - how do I fill it with butane?
  1. Ignore that other load of tosh.
  2. Do not refill your lighter immediately after using it. You should allow enough time for the lighter to cool off.
  3. The flame height adjuster on the bottom of the lighter should be set to minimum by turning CLOCKWISE with a small screw driver. The smaller, usually Phillips head, screw is for dismantling the lighter and should not be touched. The adjusting screw is a larger screw with a standard (slot) head. Some lighters come with a key to turn the adjusting screw. Some models have an adjusting wheel that requires no screwdriver. Please DO NOT FORCE the adjusting screw. If it is hard to turn in one direction this most likely means that the adjustment screw is already at the (-) or (+) limit. Try turning the other direction.
  4. Push the refilling valve with a screwdriver to let out the air inside until no hissing sound is heard. Hold the lighter away from your face. Air inside the fuel tank prevents butane gas from being injected into the tank and causes the lighter to malfunction.
  5. ALWAYS refill the lighter in an upside down position to avoid injecting air into the lighter.
  6. Shake the butane gas refill can, press the stem of the refill can directly onto the refill valve on the bottom of the lighter. Keep them in a straight position and let the gas go into the lighter for about 5 seconds. Repeat for a shorter period if needed.
  7. Allow 3-4 minutes to let gas and lighter components reach room temperature.
  8. Turn the flame adjuster counter clockwise to reach the desired flame height.
  9. Hold the lighter away from your face and body and ignite it carefully. If there is no flame, repeat the refilling process.
  10. If you experience gas leakage with a hissing sound while refilling the lighter, either you are not holding the lighter and gas can in a straight position or the stem of the gas can is not suitable for the lighter. In this case you need to use an adaptor which is usually supplied with the gas can.
  11. Premium butane is required to ensure optimum performance of your lighter. Lighters require the cleanest butane available at a pressure of 45 psi. Recommended using Premium Triple Refined Butane Gas that are packaged in 10-13 oz. cans with a metal fill tip nozzle. Non-premium butane with plastic fill tip nozzles are not recommended as they may cause inconsistent ignition and performance. Impurity of the gas can cause clogging of the burner valve or malfunctioning.
    WARNING: PLEASE, ALWAYS KEEP YOUR LIGHTER AWAY FROM THE REACH OF CHILDREN. USE COMMON SENSE IN HANDLING YOUR LIGHTER.
    Troubleshooting: If you are having problems with your lighter, make sure that:
    You are holding the lighter upside down while refilling. If you did not hold the lighter upside down, there will be air inside the butane tank. You will need to let the air out and try refilling again.
    The flame height is properly adjusted.
    You are not using cheap or incorrect fuel.
    There is no dirt or debris in the lighter. Try blowing forcefully into the top part of the unlit lighter.
Dec 15, 2008 | HHP 12V Cigarette Lighter Adapter (for the...
Need to know how to refill butane lighters
i hope not disposable ones, refillable ones with ronsion butane
Apr 24, 2008 | Kitchen Ranges
Cooking Logo
347 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Cooking Expert? Answer questions, earn points and help others
