SOURCE: I have a Dean, 4 string bass guitar with 2 EMG HZ
if i was you i would take the guitar apart and see if there is any loose wires especialy at the 1/4 inch inputs.
SOURCE: i need a schematic for a dean ml shadow
Try this site:http://www.seymourduncan.com/support/wiring-diagrams/
SOURCE: what is the Schematics to the dean metalman v
Should be pretty simple, one pickup, one volume control, one tone control:http://www.deanguitars.com/metalman_series.php Try here:http://www.deanguitars.com/services.php Toll free phone number.
SOURCE: Dean edge bass quits
The wiring in the back is so very thin and the circuit board isn't attached to anything but the wires that are attached to it. I found two weak solder joints there and one in the battery compartment (you'll have to remove it to get to the solder joints). I don't know which repair did the job, but it's working for now, anyway. I'd like to replace the tiny wires but there's not enough room in that compartment. I, also, had to replace the 4 bridge screws with larger diameter SS screws months ago as ALL 4 were stripped. Thread too fine for wood that soft. Come on Dean, step it up a notch! The bass plays and sounds great.
Jon has told you about the serial number.
Don't get Fender Fenders confused with Squier Fenders either.
Once you know the serial number you should be able to find out the year here
http://www.guitardaterproject.org/fender.aspx
Then you could try Googling:
"reverb.com Fender Jazz Bass (year)"
and you will see a range of used prices.
