Canon PowerShot S2 IS Digital Camera Logo
Posted on Aug 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens does not retract or show an image. D18 is shown on viewfider. everything ese works
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on Aug 06, 2009
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1196012
Points
12483
Lens errors (believe "E18" is showing on your viewfinder) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
1helpful
2answers
Was dropped. Now will do everything EXCEPT take photos. Lens, display, flash, etc. etc. all work fine. Just no screen image or photo when in "shoot" mode.
Sounds like the CCD or a stuck shutter blade. Try this place: www.CamerasAndParts.com They only service Canons and they are the only place we recommend for the Canons. It's all they work on and they are about half the price of most shops, plus the work is just excellent through them.
I have a blurry image distortion in the center of the picture only- everything else looks fine- a solution to my problem?
is the central of lcd divice bumped ?
1-are your lcd device show the correct image without any blur before taking the image ?
2- or this blur shown after taking the picture ?
for the first : your device lens should be clean through inner side.
for the second : the lcd should be checked , since the center of lcd may be bumped.
please let me know your checking result.
good luck
gorbesia
1helpful
I recently purchased the D80 and had no problems, it worked great and took magnificant shots. However, the other day I turned it on and the viewfinder was now, dark and out of focus. The battery was fully...
Check the mirror. The image you see in the viewfinder comes through the lens, and is reflected by the mirror. If it's dirty, it will affect the image you see. When you take the picture, the mirror lifts up, the viewfinder image is interrupted, and the light from the lens goes to the image sensor. So...if the mirror is dirty, the picture will be fine but the viewfinder image will be dark or out of focus.
The lens won't retract and when you turn the camera on, it buzzes and then tells you there is a lens error.
You are gonna hate this... but when it happened to me... I placed the camera on the table - lens down.
I then powered it off and applied pressure to the camera (to get the lens to grab its drive gear inside).
It retracted and has worked fine ever since.....
3helpful
GR-DX97U Need Help
ccd image sensor problem........Lucky you though!!
JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on 31st December 2008 and is applicable only to failure of the CCD image sensor.
This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
1helpful
JVC GR-D53AA MINI DIGITAL CAMCORDER
its a problem with the ccd image sensor, i had exact same problem with mine!! not to worry though JVC offering free repair, must be a big problem.
Check out this link http://www.jvc.co.uk/template.php?page=100102
LENS CAP
image sensor problem, not to worry though!!!
1helpful
Black screen!!!!!!!!!!!!!
CCD Failure/Lens Cap Warning Error
Please note that this offer expires on 30th June 2008 and is applicable only to failure of the CCD image sensor.
1helpful
JVC MINI DV GR-D53AA
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
