Question about Konica Minolta bizhub 250 All-In-One Laser Printer
My bizhub 250 shows c2211 error code - Konica Minolta bizhub 250 All-In-One Laser Printer
Posted by TETE CHRISTIAN... on
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: Bizhub error C2211
cant find this kind of error code, are you sure, that you have a right code and printer model ???
Posted on Jun 19, 2008
Giamma Giamma
  • 12 Answers
SOURCE: Our bizhub-250 receives a C2557
hi,
open and close front door cover to reset error.
If it persists you have to execute (TCR Toner SUPPLY)
Tell me if you need to execute it.
Bye.
Posted on Mar 20, 2009
Anonymous
SOURCE: BizHub 250 Malfunction Code C2557 - HELP!
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Posted on Oct 01, 2009
Anonymous
  • 44 Answers
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Posted on Nov 29, 2009
Bizhubman
Ben
  • 108 Answers
SOURCE: bizhub 250 All-In-One Laser Printer: Error code C3451 wont reset using Utility key at s...
• The Fusing Roller Thermistor does not detect
the required temperature within 30 sec. after a
warmup cycle has begun; therefore, the copier
does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
You may have a bad fuser section. Another reset method is a small button located on the right side of the machine under on the scanner section. Locate your network port, then to the left of the port is a small cover that can be removed, behind that cover on the left is a small black button, use a paper clip or ball point pen and press the button, this will do a machine reset. When the operation panel abort starts to load hit the number 3 button, you should see a small back circle in the top right of the operation panel. This will give you the option to do a trouble reset.
If this does not work you will need a technician to come out and replace the fuser section, make sure they bring one with them so they don't have to reschedule and come back.
Posted on May 19, 2010
1helpful
How do I solve c2557 error ?
Hi
I found your error code and suggested remedies here:
Error Codes Konica Minolta bizhub 250 Code C2557
This site is very useful as by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a pdf format Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Errors codes 2651
Could not fine that error code for a Bizhub 250. What model? check code again. Service manual no code
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5helpful
2answers
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
1helpful
How much is a fuser unit for a bizhub 250? I got a c3451 error.
around 250-280 $ (include shipping) but you may need a technician to clear counters, reset error code, and install and test the new fuser. If you want to do it by yourself, may be time consuming.....
Konica Minolta bizhub 250 code 0204
The code is an error code, it means your copier bizhub 250 is having some problem in the LCT.large capacity tray the last tray.its not opening or may be malfunctioned.
5helpful
hi,
Bye.
2answers
Displaying mualfunction detected (bizhub 250)
i will like to know how to reset the page count and service my konica myself, also my konica bizhub 250 is showing C-0204
2answers
Konica Minolta bizhub 250 malfunction error 3452
Try shutting dow the unit totally, even try unplugging it from the wall for 15 minutes.
If the error code does not go away, then a technician is needed
Bizhub error C2211
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
