Question about Kodak Photography
How can I operate my Kodak SV=1011 picture frame without a remote control
The owners manual almost entirely talks of the remote control buttons but only briefly mentions the 7 buttons on the frame. These 7 buttons only operate some of the remote control options and in many cases the button titles are changed. The unit photo quality is pretty good but several operations are not possible using the frame buttons, such as setting the clock, etc. I would really appreciate to know how to operate all the options using only the frame buttons. Thanks, Jim
Posted by jimr929 on
5 Related Answers
Anonymous
  • 301 Answers
SOURCE: Mitsubishi WS-65809 PIP/POP operation without Remote
you can buy an orignal remote from mitsubishi. they are roughly $68.00 unless you can find a universal remote that will output the correct IR command.
Posted on Feb 20, 2008
Anonymous
  • 41 Answers
SOURCE: Owners manual for kodak 5300 printer
There is a Manual in the Home Center Software under help there is a link "User Guide" or it can be downloaded from Kodak. Here is a link for the manual download.
Kodak.com 5300 support link
Once you click the link above look for the "User Guide" below that pick the language you want.
If you dont have Adobe Reader you will need that to view the file you can get it free from here
Adobe Reader
Kodak did not include printed manuals to save money and its better for the environment (less waist).
I hope you find what you need in the manual.
Posted on Mar 15, 2008
Anonymous
  • 58 Answers
SOURCE: downloading pictures into Pandigital
does it have a usb slot on the frame or a memory card?on the frame
Posted on Jul 07, 2008
Anonymous
SOURCE: Haier HWR05XC5
I have 2 of these ACs one remote is missing and the other was dropped in water. You can use the AC. Plug the unit in and hold the on/off button down for about 20 sec.or until the unit comes on. The cooling unit will come on but you will not have any control on the temp or fan speed, but you will have cool air and not just the fan running.
Posted on Jul 28, 2008
Anonymous
SOURCE: 7" Trutech digital photo frame Calendar
Use the Navigation Buttons to select "Calendar"; press Enter to confirm. To set the date, press the Stop Button and then use < and > Buttons to adjust the year and the arrow down and ^ buttons to adjust the month; press the Stop Button again to confirm. Then, use the Navigation Buttons to select the current date on the calendar display and press Enter to confirm. To exit press the Menu Button.
Posted on Nov 09, 2008
Manual for Battery Back Up 876741
Hi Terry
Found a couple of manuals, hope these help. One is 19 pages the other is 53 pages.
Kodak EasyShare EX1011 Started Manual
Kodak EX 1011 User Manual
Regards
Alan
Jul 10, 2014 | Kodak EasyShare SV-710 (8370181) Digital...
Kodak EX 1011 does not recongnize memory card
On the contrary. The EX1011 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and the frame will not recognize it as a memory card. You need to use SD cards, 2GB and smaller.
Jan 31, 2012 | Kodak EasyShare EX1011 Digital Picture...
Digital picture frame
Have you installed the EasyShare software on the computer?
Does it work when inserting the SD card into the frame directly?
You must connect the frame with the cable before the frame will be able to find the computer.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 26, 2009 | Kodak EasyShare SV-710 (8370181) Digital...
I dont have software for digital pic frame and dont know how to get pics from comp. to pic frame and i do not want to use my only memory card for pics on frame what do i do please help???
You are able top download Kodak Software on www.kodak.com/go/downloads and follow the prompts, however when connecting your frame it should show as several drives and one of those will open, the rest will give an error when trying to open. You are able to simply drag your pictures into this drive and it will display on the frame. There is no need to install the software.
Our picture frame quit showing pictures and periodically the Kodak banner pops up but nothing else
I also have this problem the frame won't move beyond the Settings menu. I have reset it and that does not do anything. I have hardly used the frame but it is now out of guarantee so I don't want to have to pay to repair it either.
Oct 15, 2009 | Kodak EasyShare SV-710 (8370181) Digital...
The kodak easy share digital picture frame won't show my pictures
Pls. check if there is any reaction when pressing the buttons onto the frame.
Check the batt within the remote.
Reset the frame.
If all fails:
Contact KODAK:
Jun 14, 2009 | Kodak EasyShare EX1011 Digital Picture...
My Kodak Easyshare 1011 has recently started to turn off
The firmware of your digital picture frame needs to be updated but since you can't do anything because after a few seconds the frame will shut down it needs to be send for repair. To process repair visit www,kodak.com/go/itg. Follow the troubleshooting guide page and at the end of the troubleshooting guide you will be able to fill up a form to send frame for repair.
Jun 06, 2009 | Kodak EasyShare EX1011 Digital Picture...
Need a remote for a sv811 frame
I contacted Kodak at 1.800.235.6325 option 14 and the part number for the remote control is 3F9766 @ $2.52. You need to contact the support number to order it.
Jan 20, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Photography Logo
335 people viewed this question
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
