Question about Altec Lansing Audio Players & Recorders
How do I turn off my Altec Lansing Baby Boom loudspeaker beeping noise?
5 Suggested Answers
Anonymous
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
Anonymous
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Posted on Nov 20, 2008
Vj24601
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
Anonymous
SOURCE: cannot connect my surround sound altec lansing system to my compu
Hello. I figured it out. You probably have a computer that only has one AUDIO OUT jack or headphone jack. Take the wire with the green plugs (1/4") and put one end in the AUX jack on the front of the Altec subwoofer and the other in your audio out or headphone jack. After turning on the power switch on the back of the Altec subwoofer, you'll see the green indicator light next to the AUX jack on the subwoofer blink and then come on steadily. YOU MUST HIT THE AUX BUTTON on the remote control, or you won't hear anything. (Make sure your PC's audio is set to line out, if it doesn't recognize the speakers automatically.) This is the same way you hook up an MP3 player or portable CD player, etc.
Posted on Feb 14, 2009
Alan Peterman
  • 7 Answers
SOURCE: output board for Altec Lansing ADA995
I've managed to fix the amp in the ADA995 when I blew the rear channel amp. There is a design fault with the voltage regulator that causes it to run very hot, which frys the plastic housing glued near it, which corrodes the circuit board trace.
Getting the sub/amp apart is a *****. But doable. You need to not only remove the screws in the back under the flat grills, but ALSO 3 screws behind the top speaker that also hold the amp in place. And getting the power supply out is another rather difficult procedure, which is needed if you want to run the amp on the bench to troubleshoot.
The amp chips are available, though no NTE equivalent, and replaceable.
Posted on Apr 22, 2012
Why does it emit a loud whistle when turned on?
I got rid of my Altec Lansing because I got white noise when the unit was turned OFF. They are not a good make. You can try moving any wires or magnetic influence away from them. I now own Bowers and Wilkins MM1 speakers which are amazing.
Bowers Wilkins MM 1
Mar 14, 2016 | Altec Lansing New Original Dell ADA995 5.1...
How do i repair dsp fw update altec Lansing imt810
First, there is NO screen on the boom box.
The issue is with whatever you have the speakers connected to.
Mar 08, 2015 | Altec Lansing Audio Players & Recorders
Altec lansing vs4121 speaker boom sound
you may have blown out the speaker or there is a miscommunication between the laptop and the woofer
Jun 15, 2012 | Altec Lansing VS4121 Speaker
How can I get to Altec Lansing UK customer support service?
call Amazon uk and tell them to give you a legit nummer for support for a thing you bought from them!
They have a obligation to give you a number, if they wont then tell them they have to take it back since you still have warranty on it..
And if they don't want to have it back they have to give you a number..
Feb 10, 2012 | Altec Lansing inMotion MIX iMT800 Portable...
IMT800 will not work off power cord, plug seems very loose in connection. Is there a way to open the deck and check to see if plug is broken within?
Try it with batteries. Likely that this the problem as it has been with all of the IMT 800/810's. It's due to the circuit board and the shoddy workmanship that Altec Lansing performed when manufacturing these units.
I'm on my second one so feel qualified to make that statement.
Jun 28, 2011 | Altec Lansing inMotion MIX iMT800 Portable...
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
My Altec Lansing VS4121 speakers have been beeping almost 3 times per second with a light buzz recently. Even when i turn off my computer it still beeps. The beeping keeps going if I plug in headphones to...
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your computer. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower.
Jan 27, 2011 | Altec Lansing VS4121 Computer Speakers
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
Powered sub
thats sounds like feedback. try giving your sattelites spacings. if they are near to each other, try to put them far from each other.
try also to turn of your microphone. that might work.
Jan 14, 2008 | Altec Lansing VS3251 Speaker
116 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
