Ovens Logo
Question about Ovens Ovens
Since a cut in electricity supply ovens do not work
Posted by Mary Pearce on
Kenmore electric range model 790.9232 oven does not work
If your Kenmore electric range model 790.9232 oven is not working and the control panel is blank, there are a few potential causes for this issue:
  1. Faulty control board: The control board manages the oven's functions and if it is faulty, the oven may not work and the control panel may be blank.
  2. Power supply issue: There may be a problem with the power supply to the oven such as a blown fuse or tripped circuit breaker.
  3. Wiring issue: A wiring problem such as a broken wire or loose connection may be preventing power from reaching the oven.
  4. Thermal fuse: The thermal fuse is a safety device that cuts off power to the oven if it overheats. If the thermal fuse has tripped, the oven will not work and the control panel will be blank.
It's best to have a professional technician diagnose the issue. They will be able to identify the specific cause of the problem and make the necessary repairs. It's also important to check the owner's manual for troubleshooting options or error codes that might be displayed on the control panel.
It is also important to check if the range is properly plugged in, or if the outlet is working properly.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18-6--/Kenmore-Oven-Won-T-Turn-On
https://www.youtube.com/watch?v=yLBpPg7dsg8
Hi.my beumatic b151 oven is cutting out my fuse on electic supply when i turn the switch to my oven on.
You sound like you have a short in the electrical system someplace. Be safe and have it checked out!
2answers
Fan not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
8helpful
New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
Aug 20, 2009 • Ovens
OVEN WIIL NOT TURN ON BREAKER KEEPS TRIPPING
This is usually indicative of a short in the oven. Unplug the oven, and clean it out thoroughly. Be sure that nothing is crusted to the element, and that the power cord is not frayed or cut. Its likely that something inside the power supply is broken, and the oven may need a new supply, or need to be replaced if it is a cheap unit.
3helpful
Oven not working
You need to detrmine if you are getting a supply to the oven element, if you are , then the new element is faulty, if no supply, then you are going to have to work back from source.
Please rate my solution.
Thanks.
Neff U1721 Double Oven - No Heat
If the fan is running then it is unlikely to be the clock/timer. Yopu need to check if there is voltage to the element but you MUST be careful to avoid an electric shock. There is sometimes a thermal cut out in line with the supply from the thermostat and that would need to be checked. If all OK the thermostat is the likely offender
Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
Top Ovens Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you an Oven Expert? Answer questions, earn points and help others
