Question about Hitachi Televison & Video
Hi I have remote RP55-27ME like to use on my Hitachi tv can you help me with code
Posted by Carlos Tavares on
ray gallant
    Top Expert:
  • Hitachi Master
  • 68,294 Answers
PERHAPS IF YOU GOOGLE THE MAKE OF TV AND REMOTE CODE LIST YOU WILL FIND JOY, PEACE AND HAPPINESS
Posted on Feb 23, 2019
5 Related Answers
skippy101
marco amezcua
  • 143 Answers
SOURCE: Hitachi tv and remote
no it is probably broken in side tack it appart and check for broken springs that hold batteries make sure they are clean
Posted on Dec 20, 2007
Anonymous
  • 163 Answers
SOURCE: i need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Posted on Jul 24, 2008
Anonymous
  • 6 Answers
SOURCE: RE: Emersom Universal Romte
goto this website this will help
http://www.thompsontv.com/rcarc.html
Posted on Aug 24, 2008
Anonymous
  • 60 Answers
SOURCE: Need code for Jensen univeral remote JR300 to match a Hitachi TV
Should be one of these codes:
Hitachi 0056, 0145, 0016, 0151
Posted on Apr 07, 2009
jose martinez
  • 159 Answers
SOURCE: need code for hitachi tv
Hitachi: 1145, 0145, 0151, 1904, 0032, 0409,
or you can use the general method:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Posted on Apr 14, 2009
Need code for hitachi tv
Three digit universal remote codes for Hitachi are: 001/ 004/ 009/ 013/ 059/ 061/ 079/ 088/ 091/ 137/ 139/ 140/ 141/ 142/ 143/ 144/ 145/ 146/ 179/ 210
To know about four digit codes, and setup proceedings,
type in this site name "Electro-help" (DO NOT copy and paste the site name from here. Doing so may lead you to wrong place) to search box of your search engine [not in the address bar of your browser], and press "Enter".
It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site, either at the bottom part of first search page, or at the top of second.
Detailed descriptions are there to help you.
Jun 07, 2012 | Hitachi Televison & Video
What is the remote code for hitachi please?
Hi
Setup codes for Hitachi TV with One for all URC 3021 remote control are:
0145, 1145
OK.
Jul 24, 2011 | One For All URC-3021 Remote Control
Need codes to t v ....hitachi
Hi you will need the model number of the remote they make about 30 ir models but here is a link to the codes just choose the model remote and click codes then scroll down in the television section to hitachi for codes. http://www.dishnetworkremotecontrols.com/
also here are some codes for dish net remotes/hitachi tv's > 523, 549, 554, 555, 585, 627, 638, 654, 655, 658, 756, 786, 788, 789, 790, 791
Jan 31, 2010 | DISH Network IR Remote Control
Remote codes
http://www.hifi-remote.com/ofa/devices-tv.shtml
Hope this helps!
Feb 26, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I have a Hitachi Ultravision tv model 53udx10b. I'm seeking the remote control code. Can u help? cole
Hi FixYa Problem,
I found a list of the remote codes associated with my internet provider's universal remote and kept changing codes until I found the one that solved the problem. Thanks for your offer, but I'm okay.
cmwallace42
Aug 01, 2008 | Hitachi Televison & Video
Programing an old hitache remote
I can not remember the nu mbers to program in the TV for the remote. I can turn on the VCR but not the TV. I know it is somehting simple like s ymbol/2 or 4/tv but it has not been working
Jun 11, 2008 | Hitachi HL01453 Remote Control
4 in 1 remote control
Hi the codes for hitachi are 0074,0082,0081,0511,0201,0616,0234,0236,0255,0232,0554,0110,0537,0075,0594,0147,0216,0143,0550,0518 turn on tv, 1.press tv button on the remote 2. press setup button until it flashes twice enter code then turn off by power button (keep repeating 1-3 until tv goes off) hope this helps.
Samsung vcr 0278 or 0455 as above. Angela.x.
Feb 22, 2008 | Philips Magnavox Learning Universal Remote
Remote code
You won't be able to use it for your dvd player unfortunately.
The code for sky is 0145.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful.
Gaz
Jan 14, 2008 | Hitachi CLU-4324UG Remote Control
Hitachi Plasma
i have dish network different brand tv but have codes for hitachi they are 1004,1006,1012,1013,1059,1060,1063,1135,1136,1145,1148,1179,1185. hope one of these helps
Dec 13, 2007 | Jensen JER-422 Universal Remote Control
Televison & Video Logo
21 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
