Ovens Logo
Question about Belling Ovens
Belling hob not working flashing e r ..oven is working
Posted by Kevin Stoneman on
5 Related Answers
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: i really need some help
If it has a timer, make sure it is set to manual.
If it is digital try resetting timer, if anologue then a hand symbol should be showing.
Posted on Dec 06, 2008
Anonymous
SOURCE: can't get my belling oven to work
Press & hold both the 'Cook Time' and 'Stop Time' buttons together and, while holding both of them down, press either the + or - button (this is the way to set the time of day). Release all buttons simultaneously. This should enable the cooking functions to operate.
Posted on Apr 27, 2009
Anonymous
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
ashburton
  • 417 Answers
SOURCE: belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Posted on Dec 22, 2009
Testimonial: "thanks ashburton i will attempt to change the element first."
Anonymous
  • 4 Answers
SOURCE: Belling XOU 252 Oven suddenly stopped working
need new element that is element code "AB20" from link below you need to remove 2 screw or nuts that holds back plate element is behind it then pull oven out remove back cover remove element wires and put every thing reverse order
element code is AB20 link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
Posted on Dec 24, 2012
We have a belling induction cooker. The trip blew now E5 is flashing on the hob, only two of the hot plates are working and neither of the ovens are working. It's only 2.5 years old.
Unfortunately, Induction hobs on domestic cookers have always been a problem. A single, one ring catering hob is $1,200 and is expected to last 2 years in an industrial environment.
There are two videos here, but I reckon you will need a service call.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01r2k0Xw_ZCF69PXpLMkc_N2QzdIQ%3A1608069741109&ei=bTLZX5KRBtfRtQb9wp6IBQ&q=belling+induction+hob+e5+error+code
Hi, I have a belling electric oven and separate grill. The two hobs on the left don't work, the grill doesn't work and the front elements in the oven itself has stopped. Is it fixable? Thanks.
Go to the circuit breaker location on your house and locate the one for the oven. Try flipping it on and off a couple of times. If the breaker only supplies 120 volts the heating elements won't work but the light and clock will. If resetting the circuit breaker fixes the problem, it will happen again, so replace the breaker to do a permanent fix.
What can I do about the hobs overheating - when on, they are only on the highest heat and can't be turned down.
THE only solution is to replace the regulators that control the hotplates.
Could prove to be expensive.
2helpful
Belling oven stopped working
Dec 22, 2009 • Ovens
My hob is working but there was a bang in the oven and nothing is working inside the oven but the hobs are working fine. Many thanks for any help
If it is a fan assisted oven, and the fan is working o/k, then I would suggest that you fit a new oven element, if the fan is not working, then you are going to have to investigate further.
Please rate my solution.
Thanks.
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
