Question about Whirlpool Refrigerators
Several LED interior lights are out on my Whirlpool fridge model: WRX988SIBM00. I replaced the LED control board/inverter in the back of the fridge but that didn't fix it.
Everything else on the fridge works. Door switches also work.
Posted by Brian G on
  • Brian G Oct 06, 2020
    I never updated this since I fixed the problem. After trying a LED driver board and then a main board, it was as simple as one interior light being bad. There are two interior light circuits, each wired in series. If one LED goes out, you lose all the lights on that circuit just like an old set of Christmas lights.
Victor Mosim
    New Friend:
  • 95 Answers
U may have bad led board
Posted on Oct 06, 2020
5 Related Answers
Anonymous
  • 262 Answers
SOURCE: Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Posted on Jan 01, 2008
Anonymous
  • 6966 Answers
SOURCE: AOC LM700 17" LCD Screen switches to black and then comes back to norm
According to LCDParts, an inverter for an AOC LM700 would cost $69.99. Specs (with picture) are available here.
Perhaps you can do a Google for lesser priced versions.
Good luck and kind regards.
Posted on Feb 08, 2008
tonyb_33
SOURCE: fridge/freezer temp lights and interior light dont work
I found a repair diagram on the web that showed the parts picture and part number and saw the box in the back lower left corner of the refrigerator that housed the circuit board.
Posted on Jun 19, 2008
Anonymous
SOURCE: Dell inspiron 6400 screen problem
I had the same problem. You need a new graphics card.
Posted on Jan 29, 2009
vinceisaac
francoise cleofas
  • 2432 Answers
SOURCE: Sharp Aquos LC-C3237U no picture backlight OK green light on
check if their is a signal on voltages around 3.3v at the inverter board if none their is a problem in the board which is in the processor.
Posted on Aug 31, 2012
Sony projection tv...Screen blinks on and off to black several times a minute...audio and everything else is fine
It sounds like either the inverter board or lamp are the problem. I would sway more towards the inverter as when the lamps die they normally do it properly.
Jan 13, 2017 | Sony Televison & Video
LG 47LN5400-UA LED picture has gone out. Audio works. Using flashlight I can see faint menu image. LED Driver or LED Strips? How can I tell?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
Dec 23, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
RCA 55" TV Model: TV LED55C55R120Q Serial: 4526-LE55C55-C201218, August, 2014 Diagnosis and repair recommendations needed.
like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 13, 2016 | Televison & Video
LED TV screen has flickered momentarily and faded to black. I have sound and power buttons light up. LED solid black, not lit. Bad LED Driver board?
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 16, 2016 | LG Electronics 55LE5400 55LE5400 55 LEDLCD...
Vizio e550i-b2 no led backlight
May 03, 2016 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
Samsung UN55EH6000 has audio, but no backlight LED as seen with flashlight test.
Feb 29, 2016 | Samsung Electronics UN55EH6000 - 55in...
The LED light is not lighting up for my programs to see them I have to hold a flash light to see them ,how can I fix this
Jan 29, 2016 | Televison & Video
Tv flashes good picture for 1/2 second and then dark. Picture is there but really dark. How can I tell if it is an led strip or the power supply board
Jan 28, 2016 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
Bauhn ATV50FHD3 no picture has sound no lights at back. I heard tv going on and off several times went to tv picture black only sound hubby testing his remote control power switch has he killed my tv
Nov 26, 2015 | Televison & Video
Refrigerators Logo
Top Whirlpool Refrigerators Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
jdthefixer
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
