LG LFX25960ST Stainless Steel French Door Refrigerator Logo
Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Water is slowly trickling out of water dispenser
I have a LG French Door Refrigerator part number LFX 25950SB and Im not getting a good stream of water coming out of the water dispenser.
Posted by chrisfam4 on
Anonymous
    Genius:
  • 1,036 Answers
This is usually because the water filter on the supply line needs replacing.
If it has not been replaced within 6 months, then this will probably cure it.
Thank you for using Fixya,com
Posted on Aug 05, 2009
Refrigerator water dispenser trickling water
The mechanical part of your water valve is not closing. replace the water valve, this should solve the problem. you may want to add an inline water filter before the valve, will improve ice quality and prolong the life of your new valve
Water dispenser very slow
Check the filter and replace if necessary.
Water dispensed with good flow. model # KBFA20ERBL01 , I replaced water filter with recommended #4396395. Now water trickles at very low flow rate. What can I do? Thanks, Jess
Any time that you replace the water filter you need to run about 2 gallons through the dispenser. The new filter is full of air not water, you just need to flush the air out of the system. The trickle is water siphoning through because the air is still in the system.
1helpful
Water is dispensing very slowly and I just
yup,
i would turn your freezer down a few degrees, you are more than likely expeiancing, whats called migration frost, cold air from the freezer, could be freezing your water resivoir or the line from it
causing bad pressure
I have a LG 3-door french refrigerator that will not dispense the ice. It makes the ice just fine and it dispenses the water just fine. PLEASE HELP!
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
Purchased a GE Profile bottom freezer April 08. Has indoor water dispenser. Changed the water filter 60 days ago. Since then the amount of cold water dispensed has slowly decreased to a trickle. There...
Disconnect the water line where it comes out of the water inlet valve and see how the flow is when you try the dispenser. Disconntct the water line at the bottom of the freezer door where it goes into the door. If it flows good here it may be freezing in the door. Open the door till it thaws.
If it's good at the inlet valve and slow at the door, some models have a way to put a plug in and bypass the filter.
1helpful
LG LFX 25950SB, the Ice Maker is not working, just hear a click
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
klh
Water dispenser is just a trickle
the biggest culprit for slow water dispensing aside from the filter is the water supply its self. check to make sure the water line isnt kinked behind the refrig, if thats ok then disconnect the water line from the refrig and run water into a bucket and observe your water flow. good water pressure would basicly fill a 2 gallon bucket in less than a minute. much less than that can cause problems. hope that helps peyton
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
