Radio Communications Logo
Posted on Feb 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is wrong with rci 2995 radio putting out half of its power ?
Stephen Miller
Level 3:
  • Master 1,645 Answers
  • Posted on Feb 20, 2019
Stephen Miller
Master
Level 3:
Answers
1645
Questions
0
Helped
865374
Points
9471
4 Related Answers
Anonymous
  • Posted on Oct 22, 2009
SOURCE: is the rci 2995 dx a good base radio for the
how can I get more modulation out od this radio?
anymhz
AnyMHz.com
  • 500 Answers
  • Posted on Dec 16, 2009
SOURCE: Break Channel...... Hey I just wanted to ask, how
For ham use which that DX model is for. the FM is preset and cannot be changed with adjustments. SSB andAM can be changed. But from factory should be good settings for amateur use.
vinceisaac
francoise cleofas
  • 2432 Answers
  • Posted on Jul 23, 2011
SOURCE: Have low speaker volume on
have you been tried to adjust the volume in full, if it was already adjusted in the volume label then the volume still the same, possible is you have a bad component part like a transistor and the amplifier ic ( integrated circuit ). if you can open the unit then look for that part turn on then after a while turn off then touch if too hot that is mean their is a shorted. hope this may help thanks.
Ironfist109
Iron
  • 3018 Answers
  • Posted on Oct 17, 2011
SOURCE: Manual 2995 RCI Needed.I would like to order one
  • Hope this helps.
Regards, Tony
1helpful
RCI 2995 DXCF. Where can I get a wiring diagram for installing a Turner Plus 2 microphone?
Hi, I use this website elektrotanya.com to get free schematics,
They also have the Ranger RCI 2995 schematics available.
Hope this helps
Where does the e-chip plug in on the ranger rci 2995
on the back of the cpu behind the frequency counter display. you will see the pins sticking out
1helpful
I got a rci-2960f cb radio does any body know anything about this radio it has a big heat ink on the botton does any body know wat watts it was putting out
The radio has a heat sink as it has a amp built into it--about 100 watts maximum output---get someone with a DUMMY load and watt meter and see what it is putting out power wise--Most of the RCI have a variable control on the front for power output.
1helpful
Radio comes on numbers do not show,beeps all the time
What kind of radio is it.. RCI?? or other.. IF its a rci 2950 stlye there is a pin on the panel of the radio inside. this will reset it back to 28mhz. then put it back, it may work. if it doesn't it will be a more major problem possibly.
  • Hope this helps.
Regards, Tony
Break Channel...... Hey I just wanted to ask, how do I turn up the modulation on my RCI 2995 DX Ham radio? I am not talking about the mic gain. Inside the radio. Thanks in advance!!
4helpful
What is the best base mic for 2995
go to this site and you can pick the brand of mic. hat you want.
http://www.a1telecom.com/shop/index.php?cPath=27
Good luck and please rate.
Contact
Is this a base power supply in the radio?
contact me direct at [email protected].
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
