C
Cesterfer Posted on Feb 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My xtc frozen edition flickers power light and then goes in to protect on high volume,what can be the problem
Grubhead
Level 3:
  • The Master 5,755 Answers
  • Posted on Mar 06, 2019
 Grubhead
The Master
Level 3:
Answers
5755
Questions
Helped
1662523
Points
11417
Have you got the right type of speakers connected to the unit? Because if the speakers can not take the power out of the unit on high volume, the system will shut it down to prevent overload. The speakers should be able to take the full power of the amp. For example it will be no use connecting 30 watt speakers to a 40 watt amp. You can of course use 30 Watt Speakers, but you can NEVER turn the volume control much pass 70%.
If the amp can deliver say 40W you need speakers of 40W or greater. Also never connect speakers that have a lower ohms rating than the stated. So if it says 8ohms on the amp you can connect 8ohms or greater speakers. Never connect 6ohms type speakers.
2 Related Answers
Anonymous
  • 624 Answers
  • Posted on Nov 10, 2008
SOURCE: Receiver goes into protect mode when hitting certain volume level
There is a problem in one of the output channels of the amplifier. That is the only reason it will do this. I work at an authorized Denon service center and have seen this problem several times, but it has never been the same thing that causes it. It has always resulted in extensive troubleshooting to find the problem. One time it was a capacitor in the pre-driver circuit for one of the channels, another time it was a transistor in the same type of circuit. I can not remember all the other causes. But without the proper tools and the knowledge of how to troubleshoot an amplifier circuit you will never figure it out.
Since this is an older model, more than 3 years old, it is no longer under warranty. They get a 2 year warranty from Denon. You can take it to any service center that works on stereo equipment and they should be able to fix it for a reasonable fee. Probable around $125 to $150 depending on their rates. It may seem like a lot, but it is much cheaper than buying a new one.
Since this is really the only option for you, unless you have the tools and knowledge, a FixYa! would be much appreciated and appropriate.
If you would like to troubleshoot it yourself, let me know, I have the service manual in PDF and can email it to you if you like and help you with troubleshooting it. But be aware, it is not an easy job.
Dave
gopakumarg43
  • 76851 Answers
  • Posted on Apr 03, 2012
SOURCE: When volume goes high, the system goes in protection and relay's clik is heared
This is not the fault with remote control. Check the load connected to the device. If overload occurs, the device will itself go to protect mode. Disconnect speakers one by one and check which speaker box causes the system to go to protect mode, when volume is incresed. Check that speaker for short.
Samsung TV - lights flicker and no standby light
Hi Ashley....Chances are your LED backlights need replacing, if you see a flash then black screen some of the lamps are shorted and the current draw is too high, and the protection circuitry is shutting down the inverter. You can check to be sure the main is working by testing the backlight on pin on the plug that goes from the main to power board, you need to see 3.3 vdc on that pin when you power the set on and it needs to stay at that voltage or you have main board issues
Xtc frozen edition amp f5,flickers power light on high volume and then goes to protect
How good is your electrical in vehicle? It sounds like your not getting enough power to it. Does it play fine at lower volume
Xtc 7500w amp
The amp might be on protection mode when both subs are driven...sign of an overloading problem. Does it work fine at lower volume levels? Check also the amp's supply voltage if it fluctuates out of tolerance level...might also be a loose connection in the wiring or terminals in the supply rails.
Jan 05, 2014 • Motorcycles
Technika lcd42 207, new power board but still no power
Flickers as in the backlight flicekers. Could be cct protection for the baclight. faulty inverter board or lighting?
My son's XTC has a frozen keyboard. All that
Call Virgin Mobile and get a replacement sent out. You have a 1 year warranty..use it!! I have had my daughter's replaced twice due to it shutting down and locking up. This usually happens during a heavy texting day.
Jan 08, 2010 • Cell Phones
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
1helpful
Eltax avr-200 no sound
Eltax AVR-200 will start up in protection mode if the amplifer went into protection mode due to high volume before it was turned OFF and it will start at the same volume level as it had before power OFF.
To correct this you must shift to another input without signal, then turn the volume down before it goes into protection mode again.
Power & protect
my amp says Lo on the digital circle on top of the amp i have a mtx 9500 bridged to the amp and it cuts out at high volumes and suddenly please help
Top The Audio Players & Recorders Experts
vince
Paul Carew
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
