SOURCE: FRIGIDAIRE FWX435RHS - FINAL SPIN PROBLEM...............
Most likely cause is partial blockage in the pump or filter. refer to your manual for access to your pump filter..most manual's show you how to do this and is not a difficult procedure. Good idea to do this on a semi regular basis as front loaders do build up with lint in this area
SOURCE: Maytag Neptune mah7500aww adding water to wash cycle problem
Your inlet valve at behind top of machine is defective; or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Pl rate if helped.............
SOURCE: kenmore 44152 3.5 high capicity washer will not spin
Open the lid of the washer and let it down gently to see if you hear a click when it closes. There is a lid switch that sometimes fails and prevents the washer from going into a spin cycle. If you don't hear the click when the lid closes, then you may need to have the lid switch replaced.
http://tclaundryrepair.com/home
SOURCE: the machine washes fine, but adds water on the drying cycle
The machine sounds faulty. You can bypass this by turning off the tap and respinning the clothes until the machine is fixed properly,
Testimonial: "Thanks for clarifying that it is a washing machine problem as opposed to a plumbing problem. "
SOURCE: Spendide 2100 won't do dry only cycle?
I own a Splendide 2100; it is installed on my sailboat. I love it, but it is a little picky. To do a "dry only", set the time you want and then ensure the dial is on "Reset" (doesn't matter which one). The LED should flash very slowly indicating it is ready to run a cycle. Turn the dial to the "Dry" indicator of the dry cycle you want. You will hear a very short gush of water (not sure why it does this) and the dryer will start. If you want to stop it before the time runs out, turn the dial to "Reset", power it off for at least a minute, then turn it back on. You should hear the lock click letting you know you can open it. Don't force the handle or you can break it.
