Question about Samsung Office Equipment & Supplies
My Samsung c1860 not turning on. It doesn’t show any display. It can scan the documents but not printing.
Posted by KEYUR PATEL on
Adorjani Laszlo
  • Samsung Master
  • 1,316 Answers
If you can scan the MFP is working.Verify the toner cartridges ar the transfer unit.The problems is in the printer mode.
Posted on Mar 31, 2019
2 Related Answers
Fixe_You
Jalal Sordo
  • 1800 Answers
SOURCE: printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Posted on Jun 05, 2009
vko007us
Vishal Ojha
  • 254 Answers
SOURCE: why i can't print mt
what error does it shows...plz specify accordingly yr prob can be resolved any can try this link
http://www.ifmdb.com/computers_hardware-hp-deskjet-f300-series-cartridge-problem-uC7aetJw.html
Posted on Aug 08, 2011
How do I scan to PDF?
w10 has this built in
so what PC is this what OS?
HP now owns samsung printers .
there are only 4 ways,
use w10 print engine way,
use HP way if offered, ask them yet?
or scan to JPG
and use and app to publish jpg to PDF, I use NITRO.
or buy PDF engine driver, to do that.
Samsung SCX-4521F Laser Multifunction Machine Print/Copy/Fax/Scan
Sep 18, 2018 | Samsung Office Equipment & Supplies
Tip
Samsung SCX-4500W restore wireless printing on cryptic error
For those having trouble wirelessly printing to their Samsung SCX-4500W printer from a Windows computer, I have this "easy" 13-step process that usually fixes my most common printing problem:
The symptom:
You haven't used your printer in a couple of days and have just hit the print button in an application you wish to print a document from. Instead of your printed document gracefully emerging from your printer, a Samsung status window appears on your computer above the task tray, cryptically announcing "The current printer port is not supported for the current printer status". You scratch your head in complete confusion.
The solution:
  1. Go into the room where your printer is. Observe that it has dropped its wifi connection and not reconnected automatically - the blue light indicating wifi is no longer illuminated.
  2. Turn off the printer, wait a few seconds, and turn it back on.
  3. Rebooting always causes a blank page to be ejected - how annoying! Open up the tray and reinsert the blank sheet.
  4. Wait for the blue wifi light to come on.
  5. Return to your computer and open the printer job queue window. Locate your document in this window with "Error" status next to it: right-click on it and select restart so its status changes to "Printing".
  6. After a while, notice the status has changed to "Error - Printing" or "Error - Sent to printer". Since restarting the job was not successful, right-click and select cancel. Press the OK button in the confirmation dialog. You may have to do this a second time before the job clears.
  7. Return to the application you printed from and re-print the document.
  8. Double-click on the blue Samsung "S" icon in the task tray. A window titled Samsung SX-4500W Series will appear in the lower right. Observe the status first says "Please wait..." then show the same cryptic message "The current printer port is not supported for the printer status". Grrrr.
  9. Check if your computer really can access the printer by opening web browser and typing its ip address. For me, it is 192.168.1.70. Alternatively, click the "Printer Setting" button in the window of step 8. Observe that the printer reports it is alive and ready for action. This is good.
  10. Check if any other Samsung software is able to use the printer: Open SmarThru 4 software, select "Scan To", "Folder", then hit "Scan" button. Observe that scanning from the printer works absolutely fine. Close SmarThru. So the problem is just the crappy printer driver.
  11. Close any Samsung windows you have open. Navigate the start menu to Samsung SCX-4500W Series->Maintenance. The installer will run in maintenance mode and find your printer on the network (and show its ip address), as well as an option to use it on "Local Port". Select the printer on network and click Next. Select "Samsung SCX-4500W Series printer driver" to repair and hit Next. The driver will re-install. Click Finish when done.
  12. Return to your application you wish to print from and activate the printing of the document again.
  13. The Samsung status window will once again appear in the lower right proclaiming "The current printer port is not supported for the printer status". Ignore this stupid message and close the window. Go to the room with your printer and with any luck, you will find your printed document waiting for you!
Once you are well practiced at this, and can fully appreciate how useless Samsung's software developers are, you can just do steps 1,2,3,4, 5, 6,11,12, and 13.
on Mar 09, 2011 | Samsung SCX-4500W WiFi Multifunctional +...
What happen when you send a document to print and just showing blank
For your printing problem, try uninstall and reinstall print drivers in your computer. For your scanning something is wrong with the scanning unit.
Jul 26, 2016 | Toshiba Office Equipment & Supplies
How do I set up on my printer to connect fax
Dear
Pl. connect the CO(telephone line) to the socket marked as LINE.
from the key board there is FAX switch select it.
To send a fax load the document face upward, if ADF is used or face downward at platen glass, press SPK or OHD or phone as marked on the key board get the audible dial tone, dial the required fax no. get the fax tone press START. If the display shows sending then alright. If display show !-SENDING,2-RECEIVING, then press the corresponding digit.
Thanks,.
Feb 18, 2015 | Samsung Xpress SL-C460FW Laser...
Installed my Hp Photosmart printer c309a to a Toshiba (Windows 7) I am able to print wirelessly. But when i try to scan -"to computer" the screen on the printer reads !! Scan Problem-try...
Please install and run the below mentioned software to automatically diagnose and fix scanning issue:
HP Scan Diagnostic Utility
After installing this utility,
  1. Press the Power button to turn on the product, if it is not already on.
  2. From the Scanner column in the Scan Diagnostic Utility, select your HP product.
  3. Click Diagnose . The Scan Diagnostic Utility diagnoses various scanning problems, and then displays a list of results. The results display either when the tool detects an error, or when the tool completes the diagnosis and there are no errors.
    If this utility doesn't solve your issue, please revert back.
Sep 02, 2011 | HP Photosmart Premium C309A All-In-One...
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
Trying to scan pics on HP Officejet 7110. Press 'Start Scan,; display on printer shows 'Scanning to Microsoft Outlook' for over one minute. I can hear the machine scanning and see the scan light working....
Nothing in or jamming document feeder tray.
Change the setup to scan to a file, rather than email.
Try a different USB port.
Reboot all.
Reinstall printer/scanner drivers and software.
Nov 17, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer x6570 won`t print photos and data, or scan...
Jun 05, 2009 | Lexmark X6570 InkJet Printer
Toner exhausted replace toner in Laser Printer SCX-4300
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
Mar 25, 2009 | Samsung SCX-4300 Monochrome Laser...
71 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
