Sometimes won't turn over when i try it.
Hi, when it dont turn over do you hear a clicking noise or is the engine turning over and just not starting.
If its the first and when you turn the key the starter motor dont turn the engine over allowing it to start you will usually hear a clicking noise and this is the selanoid inside the starter motor failing to make a connection.
If this is the case then all you need to do is get the starter motor replaced if you have any further comments or need further assistance then let me know ok
SOURCE: Burning rubber smell inside car-2003 CTS Cadillac
Diagnosing this will be subject to a process of elimination. It could be the radio, blower motor or any other accessory particularly ones with moving parts; Try switching those off and try to note when this problem occurs and what is on/whatyou are doing. Something is getting hot causing the smell so it will be a situation where the accessory will have to run a while before doing it. It is a possibility that there is an electical curcuit overheating, but less likely. Lets rule out accessories first and give us an update. GL
SOURCE: CD Mechanical Error on 2003 Cadillac CTS
take the radio apart and take them out one by one, i just fixed my yesterday
SOURCE: The AM/FM radio in my 2003 cadillac CTS faded to only static
check antenna cable connections at radio & antenna.suspect power antenna if equipped.
SOURCE: 2003 cadillac cts v6 3.2 liter. white smoke
u have a leak in the heater core the oily smell and mist is anti freeze sounds like a small leak because usually u would have a wet floor if it was large -two choices check and repair as necessary the core or can use an additive with a stop leak they usually work well on small leaks
