Question about Zanussi Dishwashers
I have a Zanussi ZDT21001fa integrated dishwasher and it keeps sending a error message with 2 beeps and it won't drain. I have checked all the tubes and the pigot but it still won't work. please help!
    Top Expert:
  • Zanussi Master
  • 66,569 Answers
Call your local repair service , i'm guessing the pump is either plugged up or has failed
Posted on Feb 19, 2019
5 Suggested Answers
Anonymous
SOURCE: Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
Posted on Jun 16, 2007
eagle338
eagle338
  • 4889 Answers
SOURCE: Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Posted on Feb 03, 2008
Anonymous
  • 706 Answers
SOURCE: Dishwasher Error code/
F5 according to the manual suggests you have an 'increase in temperature when element should be off" The possible cause : Faulty element, Faulty elecronics controller or faulty temp sensor.. In all cases they suggset you have your service reapir person resolve...
Hope this helps..
Posted on Sep 22, 2008
Garth Jackson
  • 93 Answers
SOURCE: bEEBING CONSTANTLY ADG7460 WHIRLPOOL NOT DRAINING
This dishwasher being only seven weeks old I suggest you contact the store where you bought this unit and tell them to book a service call and send a technition out to solve this,the reason I am suggesting this is that the unit is under guarentee and if you try to repair it will void any guarentee or warrentee that is on the machine.If you do work on it and something big and expensive goes wrong the store(manufacturer) will not honor there guarentee when they see that you worked on it so better to be safe than sorry.If you do not come right with them let me know and we can see what we can do from there.
Posted on Feb 05, 2009
Anonymous
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Posted on Sep 06, 2009
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
Er 2 Thermistor
There is a water temp sensor in the unit. That sensor has failed.
May 06, 2013 | Electrolux ICON Professional EDW7505HPS...
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Elctrolux dishwasher won't start, display won't light and it randomly beeps
Check continuity of the 4 small wires that connect to the control panel to the control board. They seem to break where they flex for the door to open and close.
Jul 25, 2012 | Electrolux EWDW6505GS Fully Integrated...
Bottom drawer won't clean or drain
My top draw F&P won't drain, it seems to want to go thru the cycle, but then leaves about 3 inches of water. no codes are displaying. No extra beeping. please help!
Jun 30, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Mar 22, 2008 | Dishwashers
Zanussi LS9 Dishwash error message
c3 means that the temperature of the water inside the tank is higher than 60 degrees celcious.may be you have already connect the dishwasher with to much hot water or the rele inside the pcb is stuck.
waiting for answer
Nov 16, 2007 | Zanussi 29 in. LS14 Free-standing...
Zanussi ls9 dishwasher
check your boiler,maybe there is no water there
Jun 10, 2007 | Zanussi 29 in. LS14 Free-standing...
Dishwashers Logo
98 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Renee Knafel-Bullock
ray gallant
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
