Question about Precor Exercise & Fitness
I own a precor 921S and I want to know if I can use a 100% silicone treadmill lubricant with this model. I can't seem to find any information on this. Thanks.
Posted by David Marco on
ray gallant
    Top Expert:
  • Precor Master
  • 69,148 Answers
USE WHAT YOU WANT .
Posted on Feb 24, 2019
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: HOW DO I remove silicone lubricant from the
You need to be careful if you are trying to clean the belt soa s not to damage it. Use something like methylated sprit - or some other clean that does not have oil products in it. A good qulaity computer foam cleanser also works very well.
Posted on Nov 09, 2009
Anonymous
  • 83 Answers
SOURCE: wax or silicone on my 10+ year old Precor M9.21
Use silicone to lube your treadmill.
Posted on Apr 30, 2010
Anonymous
  • 15 Answers
SOURCE: Where can I purchase a teflon spray lubricant for treadmill?
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
Posted on May 27, 2010
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: I have a noisy Pro-Form Model 285T treadmill
Hey Richard Depending on the noise it could be one of several components failing. If loud clanking or clunking noises these components are Drive Motor, Front or Rear Rollers.
If it is a loud humming noise increasing and decreasing when planting yours feet then it is either the Inductor ( square object ) or the internal windings of the Drive Motor.
Unplug your unit remove the motor shroud with a long shaft flat tip screw driver you'll be able to pin point the problem with this tool.
Now locate front shaft and rear roller tension adjusting bolt ( refer to owners Manual) plug in unit, start unit and touch flat tip on the shaft and place your ear on the handle the noise will be amplified and you will be able to locate the noise repeat this procedure on the other above mentioned components if problem is not found. GOOD LUCK!
Posted on Jul 31, 2010
Hello, Our Precor 9.21si begins slipping after walking or running a few minutes. Seems to be worse the faster you go. After about 1 mile, the house fuse blows. What troubleshooting steps do you thi
This really sounds like the results of long term use without lubrication or wax between the belt and deck. Chances are you will need to replace the running belt and the deck or flip the deck if it has not already been done. The friction builds up between the deck and belt and caused the electronic components to overheat. The machine is shutting down as a precautionary measure. It will do this only so many times before the electronics are zapped. Start with the deck and belt. Hopefully the electronics are okay. With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Repair Parts for 9 21s 9 21si Treadmills Consumer SPORTSMITH net
Feb 03, 2013 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Lubricant needed for new balance 1500 treadmill
1) the deck belt can be use 100% silicones or wax if your model use wax.
2) rollers bearing use WD-40 or similar for lube bearing.
God bless you
Nov 29, 2012 | New Balance Balance 1500 Treadmill
Need lubrication for proform 785 belt
Some ProForm treadmills require lubrication every six months or so, depending on the usage amount. Lift the walking belt and feel on the underside of the belt. If it is dry, you should lubricate it. ProForm recommends you use 100-percent, non-petroleum silicone spray to lubricate the walking belt. Do not use wax or other lubricants, such as WD-40 or a Teflon-based spray
Aug 24, 2011 | Proform 785 Treadmill
We are wondering how to lubricate the pro-form 380 E treadmill. Can't seem to find any directions in the User's Manual.
hi,
For lubricating treadmill you can use teflon based silicon lubricant. The followihg video will help you to lubricate your treadmill.
OK
Aug 16, 2011 | Proform 380 CS Treadmill !
Have a Precor M9.1 treadmill which cuts off after about 5 to minutes of use. It can be reset immediately and will run for another 5 to 10 minutes before cutting off again. The belt is well aligned and...
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
Precor Repair Parts for 9 1 9 10 Treadmills SPORTSMITH net
Mar 22, 2011 | Precor 9.21 Treadmill
After walking for 10 minutes or so, or even sooner when I am jogging, the 921 loses power and trip my house circuit breaker. What needs to be replaced? Guessing it is the power cord as the 921 is 20...
Check your Amps on the circuit that is being tripped. The treadmill needs 15 Amps to run. If you have a 15 Amp circuit that is running the treadmill and other electronics (or lights), the circuit will trip. You may need to replace the circuit with more Amps.
Mar 02, 2011 | Precor 9.21 Treadmill
Treadmill works just fine for me. i am 100 pounds, my husband got on and it went out of control and he was trying to regulate it and had to get off. We have tried several times. It works for me not for...
Sounds like the unit needs to be lubricated, Its laboring under his weight thus the foot plant technology that the precor use cannot adjust properly go to Treadmill Doctor.com and you order the lubricant from their.
Apr 27, 2010 | Precor 9.31 Treadmill
I have the Precor 9.31 and it is 4 years old. When I start going fast the power shuts off completley. I am 210 pounds and this happens to me, however my wife is 120 pounds and is not having a problom.
SOUND LIKE A LUBRICATION ISSUE DEPENDING ON THE MANUFACTURER NOW A DAYS SYN SILICON IS USED ON MOST PHENOLIC DECKS IF NO MAINTENANCE HAS BEEN DONE I WOULD ALSO CHECK THE FOR UNEVEN SURFACE AND THE BELT MAYBE TO WORN AND THE LUBRICATE WILL NOT BE EFFECTIVE , BUT ITS CHEAPER TO TRY LUBE THAN NEW BELT AND DECK. GO TO gymparts.com part# TM001 or call them @ 1-800-496-7278
Feb 03, 2010 | Precor 9.31 Treadmill
Exercise & Fitness Logo
75 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
