Question about Haier Refrigerators
Haier thermocool freezer HTF-126H,cooling inside but the outside is hot, what could be the problem for the hot.
Posted by Temitayo Adebayo on
Chris Huff
    Top Expert:
  • Haier Master
  • 6,289 Answers
Most likely designed that way
Posted on Feb 19, 2019
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: problem with cooling of HAIER HVT12ABS
not to much experience with tecs, but a tec has a hot and cold side so turn the tec around and that should solve your problem and also some good thermal paste should be used on the hot side. good luck and let me know how you got on.
Posted on Feb 22, 2008
22yooper
James Helmer
  • 828 Answers
SOURCE: freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Posted on Sep 15, 2008
Anonymous
  • 18 Answers
SOURCE: Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Posted on Dec 11, 2008
Anonymous
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
Anonymous
SOURCE: Amana Top Freezer Refrigerator is hot to the touch on the outside on the sides by the freezer. Still working fine inside. Is something getting ready to break inside?
The problem was the fan. It was hitting the metal enclosure and had stopped working. We made an adjustment and cleaned it and now it works fine and the hot spots are gone.
Posted on May 05, 2009
Haier Thermocool washine machine 8.0kg does not drain water after washing. Why?
Drain pump is blocked with debris or the drive belt is not turning the pump. Have an appliance engineer take a look.
Mar 30, 2015 | Haier Washing Machines
My haier thermocool top loader washing machine is not draining water in the wash tube
you need to locate where your pump outlet is on the machine,, it must have something stuck inside it
Oct 18, 2012 | Haier XQBM22-C Top Load Washer
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Plugged in chest freezer is cooling inside but hot to touch on the outside
yup, if you make cold theres gonna be heat. they run the lines through the case for cooling. it will get usually warm so maybe cause it's running alot to get cool initially. then it should normalize. if after a day it's still pretty hot, then it may be an old freezer and the compressor may be wearing out slowly, pumping slower and causing more heat.
Jun 20, 2009 | Freezers
jim
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Inside Not Cooling and Outside is Hot
possibly could ned a new comprossor for the fridge.
Apr 22, 2009 | Haier Refrigerators
Problem with cooling of HAIER HVT12ABS
Feb 22, 2008 | Haier HVT12ABS Compact Wine Cooler
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Aug 07, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Refrigerators Logo
53 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
