Televison & Video Logo
Norman Bellion Posted on Feb 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sharp aquos tv display appears to have shifted to the left.How can it be adjusted?
This happened after a power failure. it is NOT some sort of letterboxing issue. The entire display has shifted, leaving about 1/8th of the screen black on the rightside.
Stephen Miller
Level 3:
  • Sharp Master 1,645 Answers
  • Posted on Feb 19, 2019
Stephen Miller
Sharp Master
Level 3:
Answers
1645
Questions
0
Helped
866070
Points
9471
5 Related Answers
Anonymous
  • Posted on Aug 29, 2008
SOURCE: Sharp Aquos LC-C3242U LCD screen go's black after power on.
I have (had) the exact same problem with my Sharp LC40C32U. I purchased it at CostCo 1 1/2 years ago. Because they changed their return policy I thought I was out almost a $1,000 but decided to ask them if they could do anything. Wouldn't you know they had an extended warranty that was still in affect. I called their service people and spent over an hour on the phone with them. After going through all the troubleshooting steps they arraigned for an in home repair (free of charge).The technician that came new exactly what the problem was and how to fix it. The kicker is no parts were bad, over time the 2 grounding points on one circuit board were not making contact correctly. He explained that the problem would be worse when the set was cold, as it heated up the grounding points would make a better contact. That's why it seemed to occur everyday first thing in the morning. He took the back off, removed the circuit board and cleaned the contacts. When he put it back together he tightened the screws down fairly tight, explaining that the factory does not tighten them enough which is why I (we) have the problem in the first place. This took all of about 20 minutes. I have not had any problems since. If you live in San Diego, CA the company that fix'ed my Sharp is Advanced Electronic Service.
Anonymous
  • 1779 Answers
  • Posted on Feb 28, 2009
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Anonymous
  • 6 Answers
  • Posted on Sep 03, 2009
SOURCE: My Sharpe Aquos TV screen stays black even when switched on!
Call up Sharp, if you are part of the AQUOS Advantage Program, you get FREE in home service along with the repairs for it.
They'll give you a case number, set you up with a technician and BAM!
I called on a Wednesday and got an appt for that Saturday for the technician to come to my house.
I doubted Sharp alot less after that.
barbu51
Jacques Marin
  • 566 Answers
  • Posted on Apr 27, 2010
SOURCE: A Black square keeps appearing on screen, and wont leave
Hi big john
To answer your question;
What you have is closed caption(CC) in text mode.
To remove it ;
On the original remote there is a button labeled CC
Hit that button until you see closed caption OFF
Hope this help Cheers
decarpentier
  • Posted on Jan 24, 2011
SOURCE: sharp aquos model LC-32D40U screen goes black
The Sharp TV model LC32D40U / 41U "Black Screen problem" is a very well known issue. The inverter is losing ground contact which will prevent the back-light from staying on. The solution is to re-tighten six screws on the inverter board. You also would want to clean the copper contacts on then bottom of the inverter where the screws go through. Access to the inverter board will require some disassembly. Plan on taking at least three hours to repair. See the photo for the location of the screws. Use some "blue" locktight" on these six screws. There is actually a Sharp Technical Service Bulletin that describes these screws. Sharp wants you to replace these screws with a newer version. They cost at least $2.50 each! I think my method will work just as good using the "Locktight"_548.jpg_547.jpg
1helpful
Sharp aquos tv will not power up
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Black cloud like fogged on Sharp Aquos 37"tv
- Flickering screen
- Dim screen
- Slow start
How do i Adjust My 40 inch Sharp Aquos to 1080 p?
You do not adjust the resolution at the TV, the TV will adjust itself to display what you are feeding it. It works the same way as the computer monitor, which is done on the computer's video card to what ever you set it to.
Sharp Aquos LC-37BX6N - no display. On switching
Off/On The Power switch sudden 4 Straight lines appear on the screen ! what is that & why ?
1helpful
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
8helpful
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Need help setting up My Sharp Aquos LC-32D44U, also volume issue
GA293wJSA my friend gaveme this sharp tv. Nothing happens after I plugged it in I just get a blue screen what do I need to do to view a picture?
52 SHARP AQUOS
Either bad connection with the LVDS cable, defective LCD controller, or even a defective LCD panel. Can you post pictures?
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
