Question about Brother IntelliFax-2820 Laser Fax
When we attempt to dial to send a fax, all we get is beeping
    President:
  • 3,085 Answers
Check your phone line with a regular phone. Your fax machine is not finding a dial tone.
Plug the phone line into the LINE port of your fax machine.
Posted on Aug 05, 2009
6ya staff
SOURCE:
After dialing and scanning to send fax the machine says wait and then goes to print report and starts printing
Dear
Pl. check the tel.line, test for voice communication,if its ok and without any noise, there may be problem with fax communication line(internal), this may be tested by connecting a parallel telephone set and hearing the beep tones while sending the fax.(put the document in the ADF dial any one no. just to cut dial tone press START, ) If no beep tones in regular interval heard. its due to LIU card fault(mostly). You need to replace or repair the card.
Thanks.
Feb 24, 2015 | Canon FAXPHONE B740 Plain Paper Bubblejet
Can not send or receive faxes. Have successfully performed and passed the 6 components of the HP Fax test. Can hear dial tone when attempting to fax.
Dial from printer to your mobile phone sense the ring then send the fax sense the fax tone if fax tone not hearing you replace formatter ...
Sep 08, 2011 | HP Officejet 5610 All-In-One InkJet...
I place my paper that I want to fax in the fax machine,dial the number that I want to fax, push start, it scans the paper, I hear the fax tone and at the end I get a Beep Beep Beep and the report sending...
1) did you dial correctly?
2) are you in an office or in your own home?
a) if you are in an office, you may have to dial a 9 or someother number to dial out before you can type in your original fax number.
b) if you are in your home, then its a number of things: Fax machine not connected with phone lines properly is one big supect. Check your phone cables to make sure that the fax machine is properly connected.
Mar 05, 2010 | HP 1040 Plain Paper Inkjet Fax
I can't send faxes, the screen says telephone. It
You may need to dial a prefix prior to dialing the phone number you're trying to fax. It could be as simple as putting a number "1" prior to dialing the number.
Jun 26, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Problem with my hp 640 fax
once you dial the number you fax will automatically start sending the the Fax signal which sounds like short beeps. This is done so the receivers phone (when answered) will recognized the beeps and switch to fax receive mode.  If you are getting the recording that you mentioned above, that means the number you dialed was not successful in making the connection.  Once you dial the number you should hear the phone ringing followed by some churping noises when the other end answers the call... then other churping and gargle like sounds initially as the fax proceeds.
sounds like your are having trouble with the number you are dialing.
Hope this helps..
~enov8
Feb 24, 2009 | HP 640 Inkjet Fax Machine
Faxjet 525 will not send faxes
it is never getting a dial-tone. Phone line should be plugged into the LINE port.
Jan 28, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Problems sending faxes with B820
make sure it says doc ready before pressing start!
Feb 28, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Material I'm trying to send doesn't 'feed'
does it try to grab the paper?
do you hear anything happening before the beep?
The machine recognises that there is paper, then you should hear the communication, once it has the correct signal telling it the line is available for transmission it will feed the paper.
look at the tires and see if they turn to feed the paper, is there something in the way, do the tires turn,???
if yes clean with alcohol and try again, if the tires are too smooth then they need to be changed.
Dec 11, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
Brother IntelliFax-2820 Laser Fax Logo
106 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
