Question about Internet Computers & Internet
FAULT REF : 26987148. IT HAS BEEN 3 WEEKS WITHOUT INTERNET OR TELEPHONE CONNECTION.APPARENTLY A TECNITION WILL CONTACT ME TO RESOLVE. WHAT IS THE ESTIMATED TIME FOR THIS.
I WENT TO THE TELKOM STORE AT MATLOSANA MALL TO UPGRADE FROM 2 MEG TO 4 MEG. THE CONSULTANT SAID THE NEW ROUTER WILL BE AVAILABLE WITHIN 3 WORKING DAYS. TWO WEEKS LATER WHEN I WENT BACK THE STORE MANAGER SAID IT CAN TAKE UP TO 21 WORKING DAYS? THE APPLICATION DOES NOT REFLECT ON THE SYSTEM YET. HOW LONG BEFORE I GET CALLED TO COLLECT THE NEW ROUTER
Posted by Jacques Craucamp on
5 Related Answers
Anonymous
  • 25 Answers
SOURCE: Internet connection fails very frequently!
I will try to see if I can Be of some help...But first I need to know who your ISP is. Also I note that you indicated that you try to renew and release you do not show DHCP connected. You should be doing release and then renew, I believe that's what you meant to say? Also please describe to me how you attempted to set up static IP.
Awaiting your info...!
Posted on Jan 04, 2008
Anonymous
  • 3 Answers
SOURCE: Router Loses Connectivity or "Locks Up" over time.
supposedly the firmware 1.03 was suppose to fix this. However, I still have the problem and when i try to unplug the power to the router and plug it back in, then it often times just lights up all the lights solid and refuses to work. I have to unplug it again and again to get it to work.
It usually will work for a few weeks at a time then have a really bad day where it locks up every 10min to an hour. Gets really annoying.
Posted on Nov 09, 2008
Anonymous
SOURCE: Router works at computer store, but not at my home
Try to reset the TCP/IP stack and the Winsock by the following way:
In the Start menu -> Run enter cmd.exe (press OK or hit Enter)
In the black command prompt enter the following commands:
netsh int ip reset reset.log
netsh winsock reset catalog
Hope this helps.
//Feri
Posted on Mar 18, 2009
Anonymous
  • 67 Answers
SOURCE: Internet connection drops within 5 min after (re)booting Airport
Speak with your internet provider, it sounds to me that the apple people didnt know what the problem was without getting down and dirtyy with it so they replaced it hoping for an easy fix. Seems to me that either the internet signal is being interrupted between the isp and your home .. or the motorola modem is having problems. I have never been a fan of motorola modems to begin with. Also the rentals u get from cable companies are used.. and typically subpar bottom of the line equipment that fail often. IF you think you will be using cable internet for years to come, purchase a linksys modem, as it is you are paying $3-5 a month for the rental of the modem. But I digress, speak with your isp and see if they cant troubleshoot the problem.. if 2 airports are having the same problem the chances of it being the airport... slim to none. good luck with all of this post again if nothing changes.
Posted on Aug 31, 2009
SOURCE: A department store plans to upgrade its IT
HI
i have seen your requiment
we have a devloped software for online orrder appilication along with all kind of report and up-gration of order procesing we have allready implimete in company in india
if your you would like to know more about then please contact us
M/S IT INN Enterprise - india
my email is ([email protected]) or ([email protected])
Posted on May 31, 2010
I would like to do a follow up on a fault reported on Tuesday the 30/01/2018 a business line 011 425 2645 ref 308CRZ300118 tsekema consulting engineers follow up ref 1069184
No offense, but you have mistakenly entered phone number and information on an internet based service that has no connection with a phone company in any country.
2answers
Why are the orange and blue lights my Dish/Netgear duelband blinking
Orange light means no internet connection.
Check the cable and settings.
3helpful
Paypal telephone number
If you had paid by PayPal, you should contact PayPal customer service (support) ... 1 (888) 221-1161 ...
2answers
Movies wont load
Check your internet speed at http://www.speedtest.net/
if it seems slow then your videos arent loading because your internet is not fast enough
Oct 25, 2013 • Netflix
I have a motorolla 2210 modem and lynksys wrt54gs router. how can i link these two and be able to connect the internet by using wireless?(that is without the use of the ethernet cable but by airport...
Hi
In some countries, Broadband/LAN/Ethernet Wall Sockets are available for Modems to plug directly into.
In other countries, Broadband Internet services come via the telephone line and are split to avoid conflict with Telecommunications Data by using an ADSL Filter.
Below are illustrations for both scenarios.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
DIRECT CONNECTION BROADBAND NETWORK DIAGRAM
virtual_a_32.jpgADSL FILTER CONNECTION BROADBAND NETWORK DIAGRAM
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
2answers
HOW TO EMAIL SCANNED DOCUMENTS FROM HP J4580 DIRECTLY?
It is not possible to email the scanned file directly through the printer. However, you may send fax over the Internet
You may subscribe to a low cost phone service that allows you to send and receive faxes with your device by using the Internet. This method is called Fax over Internet Protocol (FoIP). You probably use a FoIP service (provided by your telephone company) if you:
• Dial a special access code along with the fax number, or
• Have an IP converter box that connects to the Internet and provides analog phone ports for the fax connection.
NOTE: You can only send and receive faxes by connecting a phone cord to the port labeled "1-LINE" on the device. This means that your connection to the Internet must be done either through a converter box (which supplies regular analog phone jacks for fax connections) or your telephone company.
Some Internet faxing services do not work properly when the device is sending and receiving faxes at high speed (33600bps). If you experience problems sending and receiving faxes while using an Internet fax service, use a slower fax speed. You can do this by changing the Fax Speed setting from High (the default) to Medium. For information on changing this setting, see Set the fax speed. If you have questions about internet faxing, contact your internet faxing services
support department.
(Ref from the manual of the printer.)
Hope this helps.
3answers
Telephone connection
what router is it its a voip router like vonage
Computers & Internet Logo
Ekse
 Francisco Mauricio...
 Grubhead
Grubhead
