SOURCE: Kenmore dryer makes roaring oise when the drum turns
I have the same problem. I thought originally it was the seal around the drum but we pinpointed it to the fan motor. We think there is something wrapped around the fan motor or the bearings is going out.We would have to take everything out the drum and belt and motor to get to the problem. If you take the back panel off and take the lint trap off you can turn the fan and you can hear the loud noise. We tried spraying wd-40 around the fan pin but don't get any on the motor. It will burn it up if you do that. But it didn't work so you will have to take everything out.
Posted on Feb 03, 2009
SOURCE: whistling noise when accelerating
you most likely have an aftermarket radio installed
the noise you hear is engine noise, if yo turn your radio off it will go away
this can be fixed by either getting better wiring for your aftermarket radio or by installing a noise filter, you can purchase that at most big electronic stores
Posted on Oct 02, 2009
SOURCE: dryer does not start, makes a high pitched whistle
Have you check to see if the belt is off track or broken.
Posted on Nov 13, 2009
SOURCE: kenmore dryer making rumbling noises
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
Posted on Dec 13, 2009
SOURCE: kenmore dishwasher making whistling noise
Could be a clogged spray arm... take it out and give it a good cleaning. That might help.
Posted on Feb 05, 2010
