Refrigerators Logo
David Antonowich Posted on Feb 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Coldspot 106.589 fans stopped working after power outage and brief period on generator.
I have a Kenmore Coldspot 106.58902801. After a recent power outage, and a brief period on a generator, both compressor and evaporator fans stopped functioning. Compressor still hums and is warm/hot to touch, coils inside freezer still get cold and build up frost. No working fans though. Any Ideas?
Chris Huff
Level 3:
Top Expert:
  • Kenmore Master 6,289 Answers
  • Posted on Feb 19, 2019
Chris Huff
Kenmore Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2020237
Points
74913
Control board d probably damaged from power surge.
5 Related Answers
Techsim
James
  • 59 Answers
  • Posted on Nov 03, 2008
SOURCE: Amana SxS fridge not cooling or freezing
You have a sealed system problem. There is either a small leak or a restriction somewhere in the tubing. This isn't something you could've caused so don't worry about that. Unfortunately this isn't something you can fix yourself either. You require a certified refrigeration technician to fix this problem.
Anonymous
  • 8 Answers
  • Posted on Nov 05, 2008
SOURCE: Warm refrig and freezer
You probably need some refrigerant added. There probably is a leak in the system that caused the lack of refrigerant. Get the leak fixed and add refrigerant before you blow your compressor too. Or get a new fridge.
Anonymous
  • 17 Answers
  • Posted on Feb 10, 2009
SOURCE: ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Aug 25, 2009
SOURCE: Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Testimonial: "You were right, thanks for your help. The control board was bad. That is what I suspected, but I wanted a second opinion."
Anonymous
  • 47 Answers
  • Posted on Nov 11, 2009
SOURCE: Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Testimonial: "Thank you for the response Fridgie!"
Kenmore coldspot 106.55602400 Stopped working and then started back
Make sure that the condensor coils under it are clean. Behind lower bottom grill. If their plugged up with lint and dust it'll cause all sorts of cooling problems.
That's where I'd start anyway.
Best to you.
Sharp lcd 60 nonstop flashing power light
Have you had any recent power outages? Try a different outlet of possible and see if the tv responds. If it doesn't try a hard reset.
The reset is at the back to the TV, so turn the back of the TV out.
2. Locate the Power plug at the back to the TV.
3. Then near the Power plug there should be a small hole, use a paper clip or a needle and push into that hole for a brief period.
4. Now start the TV and see if the settings has going back to the factory default.
Kenmore coldspot not working properly after power outage
I am glad you made it thru the storm OK. I am in New Orleans and I am no stranger to what you guys went thru.
First, are you sure the compressor is running?
Post back to me.
After power outage Kenmore Coldspot model 10653594300 is not cooling or freezing. Is there a way to solve this?
hi.ummmm.power cuts and surges r not very healthy.u'll need to check motor first and board.check if motor is running and warm and condenser fan is on.if motor is hot and not running thennn i think your motor is faulty.good luck.ali
1helpful
Kenmore Coldspot 25ssa. After power outage the refrigerator trips breakers and GFCI
Either the compressor or the start device on the compressor is shorted out. More than likely the compressor, hate being the bearer of bad news
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
1helpful
Middle part between doors are extremely hot on my Kenmore coldspot side by side
TAKE THE BACK COVER OFF THE REFRIGERATOR. SET UP A COOLING FAN TO COOL COMPRESSOR. YOUR CONDENSOR FAN MOTOR HAS STOPPED WORKING.
Describe your Kenmore 53652 / 53654 / 53659 Side by Side Refrigerator Unit is not cooling. Stopped working after power outage
Kenmore Coldspot 106.53652300
I just fixed my neighbors fridge that suffered from a power surge. She explained that she smelt a burning smell in the kitchen and the next day the fridge and freezer were not cold. Of course she did not share the burnt smell part until after I discovered the starter relay and the capacitor were burnt on the compressor. She purchased the new starter kit and capacitor from a local supply company and while installing them I discovered the compressor fan was not running which also meant the compressor was not getting any power. I removed the screws that held the control panel on the fridge side (right side) and inspected the circuit board which I discovered a burnt trace on the board for the compressor control relay. I fixed the board by soldering a piece of solid core wire across it and it works great!
Make sure you shop around for your parts. The BIG local supplier here in Tulsa wanted $65 for the starter kit and $65 for the capacitor. We shopped around and found another supplier in Tulsa that sold them for $25 each and they were FSP parts!
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
