Question about Bose Audio Players & Recorders
How do I install Bose connect on my iPhone - Bose Audio Players & Recorders
Posted by Clyde Parnell on
How can I fix connection problems with Bose Series 2 Headset? My Bose Series 2 bluetooth keeps dropping and reconnecting to my iPhone 4s on the last IOS update 7.x ... how can I fix?
Hello. I gave one of these as a gift to my friend and he had the same problem as you. I google EVERYTHING, and the Bose website states they manufacture products that are made to last, and if you have ANY problems you should contact them. What I found is there are software updates for your headset (go figure), and I think if you register with them they will email you when that happens. I know this will work because even my friend was amazed (he was ready to throw his away). This is the link to the page that will lead you to the software updates for both mac and windows:
http://worldwide.bose.com/downloads/en/web/bose_bluetooth_system_overview/page.html
Bose repairs
It may be expensive to have someone replace the connector. One option is to squirt some silicone around the base, being careful to still allow contact to be made to the iPod dock connector. You could get a dock extension cable (see link below). It may fit better and will reduce the strain on the Bose connector. If it's still loose, you could glue the extender cable in.
Alternatively, you could use a 3.5 mm audio cable to connect the iPod headphone jack to the Aux-in jack on the back of the Bose. Just living with it may be prudent.
Amazon com 30 pin Male to Female Dock Extender for iPod and iPhone...
Cant connect Macbook to Bose Soundlink Wireless Music System
What I did to connect to BOSE wireless speaker to my MacBook air was go in advance settings and uncheck all three options there and then press the wireless button until it beeped--> then I was able to pair it to my laptop. Success!
When my iphone 4 3G is docked in my Bose Sound Dock, it says "This accessory is not optimized for this iPhone". I'm confused because this Bose is made to dock iPhones. Plus there is no sound....
Unfortunately, the iphone 4 is not the same as the previous models of iphones. I have run into problems with similar products where the iphone 4 will not work, but the 3rd gen will. If you know someone else that has an iphone 4, test theirs to verify that its not a problem with your phone. There is a high possibility that your sound dock is not compatible with the i4.
Iphone wont charge on Bose iDoc
There are many devices that worked with the original iphone that will not work with the 3g. Be sure that when you buy docking stations that the Iphone 3gs is included in the list of supported devices.
I have a Bose SoundDock II and it won't work well with my iPhone as promised. I get an error message that they weren't made to work together. Sometimes it will work and then sometimes it won't work unless...
The bose soundock 2 has some issues regarding the different generations of iPhones. In a forum (http://forums.macrumors.com/showthread.php?t=361259&page=2) if you're using an iPhone 3GS bose has a separate port for i. Do check with Bose regarding the compatibilities of its SoundDock on different generations of iPhones.
Is the Iphone compatable with the Bose SoundDock, 035703
Yes but only if you buy it direct from Bose.
They will make changes to ensure it is compatable and its FOC
Top Bose Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
