Question about Xerox Office Equipment & Supplies
HOW DO I SOLVE ERROR CODE 42-345 ON A XEROX 7120
Terry
  • Xerox Master
  • 11,377 Answers
docukaaf
    Habit-Forming:
  • 38 Answers
There is aproblem whith the transfer belt unit
Posted on Feb 23, 2019
1 Related Answer
ali shafiei
  • 12 Answers
SOURCE: Error on wc 7120 xerox 124-315
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
hen look at these 3 locations and see if they match, If they do not set them to match the machine speed.
Posted on Mar 13, 2013
7120 cartridge error
bad chip on one of the toners, or maybe one of the drum
whats the error code
Apr 08, 2014 | Xerox WorkCentre 7120/P Printer
Xerox 7120 error code 093-320 reset
bonjour j'ai un code erreur sur ma xerox workcenter 7125 je trouve pas de solution si qlq px m'aide merci d'avance code 093-320
Feb 05, 2014 | Xerox DocuColor 240 All-In-One Laser...
Xerox 7120 activation code
i need activation code xerox workcentre 7120
Nov 25, 2013 | Xerox Office Equipment & Supplies
Error 071-210
An error occurred when using Tray 1. Turn the machine off and on. Contact the Xerox Welcome Center if the problem persists.
Aug 29, 2013 | Xerox WorkCentre 7120/P Printer
Xerox 7120 waste toner error ...
The trick about cleaning out the waste toner container is you have to also swab out the clear plastic piece the optical sensor reads so the device knows the waste toner is full. Clean that out and you should be able to get more than a weeks usage out of the waste toner container.
Hope this helps.
Aug 23, 2017 | Xerox Office Equipment & Supplies
391 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
