WIRELESS TV SPEAKER - MY SPEAKER NO LONGER HOLDS A CHARGE. CAN I GET A NEW BATTERY?????
Posted by EDITH PAYNE on
Stephen Miller
  • 1,645 Answers
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Alternator and battery
the wire may have become corroded at the starter or shorted out sum where check the wires from the alternator to the battery
Posted on Feb 15, 2009
Howard Galley
  • 197 Answers
SOURCE: Battery no longer holds charge longer than 5
no, may have a problem, the battery needs testing to see which is faulty.
Posted on Sep 28, 2009
vanherringto
J. Van
  • 1738 Answers
SOURCE: the battery on my tomtom 720 no longer holds the charge
You can purchase a new battery on eBay for less than $20 including shipping:
Click here: http://bit.ly/bgoqZ0
Posted on Feb 07, 2010
brector3
shaveroutlet.com
  • 1640 Answers
SOURCE: Shaver no longer holds a charge for longer than 1
You can repair yourself if you are able to solder the new battery pack into place. You will find the correct batteries at shaveroutlet.com. See link below (you will need two batteries)
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
If you are unable to do this yourself, shaveroutlet.com can do it for you. See link below for information
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Posted on Nov 04, 2010
Testimonial: "Thank you"
SOURCE: My Philips 9FF2 photo frame
the Philips 9FF2 photo frame has an internal rechargeable battery inside the photo frame. So in other words, the Philips 9FF2 photo frame needs to be disassembled for you to be able to access the battery, then make necessary replacement.
With the Philips 9FF2 photo frame turned off and remove from the charger, get a screw driver, use it to disassemble the unit to take the back cover apart in order to gain access to the internal part to get to the battery.
Remove the battery, take it to any electronics part store in your area and get a battery replacement. It is not necessary that you get a Philips battery, all you need is a battery with the same size and volt/watt.
I hope the above is clear.
Good luck.
Posted on Jul 18, 2011
My headset will not charge fully and after a couple of hours needs re charging light does not flash for long
If it's old then the battery has probably worn out and no longer holds much charge. See if it can be replaced.
Dec 29, 2014 | Plantronics Cs540 Wireless Headset
L have the Extreme Mac Soma 360 Wireless speaker. The Speaker no longer accept the charge from the DC power supply. what can I do about this? l have gone to the retailer where I purchased the unit and they...
Did you try the xtrememac.com website? It looks pretty poor, but there is a contact link that has a form to contact customer service. The problem is either in the charging circuit or the battery. I don't know how you charge it, so I can't offer much other than the connectors are usually the culprit. The other possibility that comes to mind is the battery. If it's the battery, you'll need to contact them. Batteries only recharge so many times.
Dec 08, 2014 | Audio Players & Recorders
Big Blue Live won't charge
+1 We're having the exact same problem with ours. I haven't been able to find any solutions. Help anyone?
Aug 13, 2014 | Brookstone Big Blue Live Wireless...
I have a n=Norelco 7160XL Smart Touch that won't take a charge do I need a new battery???
If the shaver no longer holds a charge as it should, you will need to replace the battery. You will find a compatible replacement battery for model 7160XL at shaveroutlet.com. See link below
Dec 03, 2010 | Norelco SmartTouch 9170XLCC Electric...
Battery not holding a charge. Intermitent power at ignition switch.
When a batterey no longer holds a charge, it is time for a new battery. What is the date on yours? If it is older then 48 months ... start looking.
Thanks for your interest in FixYa.com
Aug 02, 2010 | 1995 Volkswagen Passat
The battery on my tomtom 720 no longer holds the charge
Feb 07, 2010 | Tomtom GO 720 GPS Receiver
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Gp280bvk x3
I have the same headphones. I went to Batteries Plus and purchased a similar battery, NUON, NU67, 3.6v 320mAh. The original battery is 3.6v 280mAh. The 320mAh holds the charge longer. You must swap the connector from the old battery to the new battery in order tomake it work. This can be done two ways, carefully removing the connector or cut, splice, solder and insulate the battery leads. Removing the connectors is tricky because the leads lock into place when inserted into the connectors. Good Luck.
Jan 16, 2009 | NAD T762 Receiver
Samsung WEB410 bluetooth headset won't hold charge anymore
Well if it holds no charge you will most likely have to replace it as it is the battery inside the bluetooth headset in otherwords the battery is buggered lol. do you still have the headset and the charging cradle?
Oct 15, 2008 | Samsung WEP410 Bluetooth Headset Wireless...
133 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
