Question about Frigidaire Refrigerators
Hi temp error on Frigidaire side by side. Have reset and unplugged. Now getting frost at the top of door on freezer side.
Posted by mmld1963s on
Mr.Mike
  • 580 Answers
Hi there, I am not sure what your asking. There are NO user serviceable parts inside the unit- and it sound like your temperature sensor failed or another part related to the sensor or thermostat- also the temperature controller could be damaged- is it out of control in the freezer and fridge? There is not much you can do beside call for help if you have already reset it. good luck
Posted on Feb 18, 2019
5 Related Answers
Anonymous
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Posted on Feb 17, 2008
Anonymous
SOURCE: Frigidaire Refigerator
TEMP FIX i found remove hinge cover top of left door and unplug the Icemaker and fridge will run again havent figured out the problem with icemaker yet though
Posted on Feb 19, 2008
David Coomer
  • 1073 Answers
SOURCE: What can I do to get rid of frost build-up (more than 8" long & 1/2" Deep) on my NEW FROST FREE FRIGIDAIRE FREEZER GLFU2067F?
contact 1-888-77-lowes if you havent done this call, have them create a case file on this, tell the person that you talk to that if you try this solve and it dont fix the issue I want a new machine if they agree to this do the door replacement if they don't take it back to lowes
Posted on Apr 10, 2008
Anonymous
  • 71 Answers
SOURCE: Heavy frost layer at top of freezer
Your freezer is low of freon.
Posted on Dec 24, 2008
My frigidaire freezer upright has an error message door ajar
Sounds like the main control board to the unit needed to be reset and with the resetting it has caused a communication error with the door sensor. Contact a service tech to move forward with a repair.
Sep 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door was not sealed tightly for about a day resulting in some frost inside freezer. Door appears to be closed but door ajar light is still lite and alarm is still beeping. What do I need to check?
The door seal has a magnetic property to it. Until the freezer gets to a certain degree the magnetic porperties of the door seal dont react properly. Make sure the door seal is properly adjusted. If the door was left open it could have semi warped the door. This gets corrected when temp drops to correct temp. Reset freezer by unplugging and waiting for a few minutes. If problem persist contact appliance technician.
If you have any more questions you can comment me back.
Jul 28, 2011 | Frigidaire Freezers
My Frigidaire freezer (not frost free)won't stay cold
look at level side to side , and front to back. if not level door can leak . you will see water where it is leaking. check defroster is if staying on .
Feb 18, 2018 | Frigidaire Freezers
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire FRS26ZGED side by side fridge - 15 years old - freezer side works but refridge side won't get cold. I unplugged it and unloaded the food and now I would like to test the temperature control unit...
The problem is not with the temp control but more with either the evap fan in the freezer section or a heavy frost build up on the back wall toward the bottom section of the freezer. If you have more frost than usual more than likely the defrost t-stat has gone bad which is not a costly repair. The fan you should be able to hear also with the freezer door open. If you do not hear it the fan has gone bad and needs to be replaced. Hope this helps
Feb 02, 2010 | Frigidaire FRS26R4C Side by Side...
Upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Mar 28, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Feb 18, 2008 | Refrigerators
Frost accumulation on ice maker
Normally the frost is taken away during defrost so if things get worse we need to look at the defrost timer.If freeze temps.begin to rise let me know, Thanks JT
Oct 24, 2007 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
63 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
