Question about Hotpoint Washing Machines
My Hotpoint WML540G will not start the wash cycle from the beginning nor will it rinse, spin or empty when on A, B or C
Posted by Mrs D Maher on
Mr.Mike
  • 580 Answers
Hi there, check out page 13 toward the bottom
https://www.manualslib.com/manual/71053/Hotpoint-Wml-540-P-G-A-K.html?page=13#manual
good luck
Posted on Feb 18, 2019
Testimonial: "Thank you. My husband tried it previously! He has checked the belt, motor an all seems ok. Thinks it may be the control panel PCB which is expensive for a 9yr old machine."
  • Mr.Mike Feb 18, 2019
    Yeah I never advise consumers to open electronics but it sounds like your husband has the right idea- Washers aren't too complicated to understand the workings of it and sounds like he is on tract- replacing the board is better is on eBay- buying that stuff new seem hardly worth the repair. Good luck and Thank you
5 Related Answers
Anonymous
  • 163 Answers
SOURCE: washing machine won't start cycle
you dont say if the water lever is ok, asuming is yes the water level switch is the problem,, unplug the machine and open de upper side to access to the water level switch check the thin hose to be conected to the switch and is not broken,, nock the switch with something like a screw driver if not replace the switch..good luck...
Posted on Jul 24, 2006
douglas smith
  • 1462 Answers
SOURCE: stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
Posted on May 08, 2007
Anonymous
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
Anonymous
  • 9 Answers
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Posted on Apr 20, 2009
Anonymous
  • 116 Answers
SOURCE: washing machine will not advance through the wash cycle
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Posted on Aug 12, 2009
Does not empty at end of wash cycle (not blocked or pump)
faulty program board not progressing
call a technician
Jan 01, 2018 | Hotpoint WMA46 Front Load Washer
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
Nov 14, 2009 | Hotpoint WMA40 Front Load Washer
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washer Won't Rinse (Hotpoint)
Suggestion: Try cleaning your outlet filter. This needs periodic cleaning, according to your usage. Refer to user's manual re. the cleaning. When it is the rinse problem it usually is the filter block.
Oct 05, 2007 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
Eric Taylor
Richard C Cohen
Richard C Cohen
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
