Question about Bosch Ovens
How to set the clock on an old Bosch Oven model number HBN212TGB/01 following a power cut
There are 4 controls left hand one has a bell symbol next two have an arrow pointing to the right 4th one has a hand symbol on it. Additionally there is a knob that rotates to advance the clock. Seems to be mostly mechanical
Posted by Neil Carruthers on
  • Peter Flynn
    Peter Flynn Jul 01, 2020
    Got the same but can't find out which combination of buttons puts it into SET TIME mode. Anyone know?
ray gallant
    Top Expert:
  • Bosch Master
  • 69,148 Answers
WELL THEN TURN THE ONE THAT LOOKS LIKE A CLOCK AND SEE WHAT YOU ACCOMPLISH
Posted on Feb 18, 2019
Testimonial: "There is no button that looks like a clock. Just the ones I mentioned"
  • Peter Flynn
    None of them.look.like a clock. Four buttons: bell, arrow with two bars, arrow with one bar, and hand. Then a knob to.turn, but no way to find out which combination of buttons put it into SET TIME mode.
5 Related Answers
Anonymous
SOURCE: tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
Posted on Jul 24, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: SELF CLEANING WILL NOT ACTIVATE, GE XL44 MODEL JGBP32AES OVEN
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 09, 2010
andrewmelic
  • 7 Answers
SOURCE: MY KLEENMAID SCALA OVEN/GRILLER
Try here: http://www.kleenmaid-appliances.com.au/ovens-care-kleenmaid.aspx
Posted on Apr 14, 2011
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: We have a Bosch double
Hi
Please follow this video for replacement:
Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 22, 2011
ginko
Ginko
  • 19396 Answers
SOURCE: I have moved into a
Hi.
Finding the exact model is difficult. There are many different AEG ovens with the same buttons. In the last ten year most AEG with five buttons have the same sequence and buttons like yours.
You can use a manual for any similar model to understand how to use the oven. Oven specifications will be different.
Your oven is probably a competence with five buttons display.
Here a single oven (5258)
Here double (5230)
Here a different Competence series (I posted the double 5238, there are many more)...as you will notice programmed is made in the same way on all AEG five buttons. If oven is double you have two couple of knobs, each one for one section.
Posted on May 25, 2011
I cannot get the big oven on my belling db90 to switch on. the clock is flashing 00:00 auto
Set the clock to manual....a hand symbol..... then try again....the oven wont work on auto unless you set time on and time off
Oct 06, 2017 | Belling Ovens
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
My clock display is also not working and the oven will on stay lit if I hold the oven knob manually ??
Have your make and model number ready and go to repair clinic dot com and it may show ya. Good Luck
Jun 11, 2015 | Ovens
How do i set the clock on Whirlpool built in double oven? Can't find a model number. 5 buttons from left to right. Alarm bell, clock with hand at 12, clock with hand at 3, + and - signs. Pleas
The model number is usually located on the side of the door or on side of the oven cavity area near the door opening. Sometimes if you have a drawer or warmer the model number is located on the oven side of the drawer or warmer (sometimes not directly facing you but on the side of that area. If the oven is electronic you press a clock button or you hold one of those buttons for a couple of seconds like a start or set button. The model number though will help you find a user manual and it for sure should be clear. I hope this helps you.
Nov 16, 2014 | Whirlpool 24" Double Electric Built-In...
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
My oven wont work afte a power cut its flashing oo:00 auto and I dont have a manual
you have 2 buttons one pops out for adjustment the other is only a push button push the left hand one repeatedly till a red clock symbol shows at top of clock then turn right hand knob to set time wait a few seconds and clock will set itself.
Nov 16, 2009 | Neff B1421 Electric Single Oven
We have a Belling oven that we can't turn on. The numbers in the display are flashing and we can't figure out how to reset this or to turn it on. There are six buttons from left to right, one labelled...
We solved this by pushing both the "start cooking" and "stop cooking" buttons at the same time (these are the ones showing a pan with steam coming out of it and a pan that says stop above it). While holding these down we used the plus and minus buttons to set the time. After doing this we were able to turn the oven on.
Oct 25, 2009 | Belling XOU482 Electric Double Oven
My whirpool oven display reads stop, how do i turn it off?
Hi
This "STOP" message appears when either the cooker has been switched off at the mains or there has been a power cut. What you have to do is a s follows:
1. The knob on the left should be turned anti-clockwise ONE click only.
2. Press the button between the two knobs (under the display) ONCE only. You will now have got rid of the word "STOP" and it will be replaced by _ _ . _ _ symbols.
3. Press the same button twice more or until "12.00" is shown. This is the 24hr clock and can the be adjusted up or down by turning the right hand knob clockwise or anti-clockwise. Its always recomended that you set the clock before useing the oven although you dont have to.
4. Now you can operate the oven as normal.....Good luck with that!
Regards Ian W.
Jul 31, 2008 | Whirlpool AKZ159IX Oven
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
348 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
