Computers & Internet Logo
Question about NetGear Computers & Internet
How to connect PC to netgear WIFI extender
Posted by Terry Kelsey on
  • Lee Parker
    Lee Parker Feb 19, 2019
    Usually those have instructions on the extender. I believe you open a browser and type on mywifiext.com to set it up
  • Anonymous Nov 18, 2021
    RTM at netgear.com
mia henry
    Habit-Forming:
  • 115 Answers
By connecting to your existing WiFi network and enhancing coverage, the NETGEAR range extender enhances your home WiFi network. The steps below will assist you in setting up your extender.
We recommend using the Nighthawk app to set up your extension on our latest devices. See the following articles for more information:
https://pnews.org/boost-your-speed-with-netgear-nighthawk-r7000/
Posted on Nov 18, 2021
5 Related Answers
SOURCE: My computer freezes when connecting WIFI adapter
Does this happen if you try connecting it into all USB ports? Try another USB port. Do you know if your USB ports are 2.0?
Posted on Mar 30, 2009
Anonymous
  • 854 Answers
SOURCE: Netgear 824, security = intermittent WiFi connectivity
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username ([email protected]) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 13, 2009
Anonymous
SOURCE: problems with WiFi netgear WNDA3100
the drivers should be installed in windows 7 by default, their so called "smart wizard" has some compatibility issues with windows 7, I get it to load up and it will shut down or glitch out. What I did was uninstall the downloaded driver and use the default windows drivers, flipped the switch off to my built in G wifi adapter and the netgear automatically kicked in and took over as the default wireless adapter.
Posted on Feb 11, 2010
SOURCE: I am trying to install
For that you need to check WAN settings and also make sure local ip settings gateway should be your router ip address. Make sure WAN settings are fine connect internet cable to WAN port of router. Then check. You can configure router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 10, 2010
Anonymous
  • 27 Answers
SOURCE: netgear wifi extender schematic
Look it up from the manufacturer
Posted on Aug 06, 2012
2answers
How to set up netgear ex6100 wifi range extender
  1. Plugin your extender in electrical outlet.
  2. Place your extender near your router when first time your are setting new extender.
  3. Launch any web browser and enter mywifiext.net. The New Extender Setup page displays.
  4. In the Password section, type the existing WiFi network password. Default user name is admin and password is password.
5. Click continue and a message box displays saying that your extender is connected to the new extender WiFi network
6.
Now, you can connect your device to the extender network, go to the WIFI settings and connect to the extender's new network.
7.
Netgear EX6100 Setup is successfully completed now place the extender at the desired location and enjoy seamless Connectivity.
2answers
Netgear extender not connecting
There's quite a bit to know about using WIFI network extenders / repeaters. Have a look here;
Simple Wireless WIFI range extender expander repeater
2answers
Mywifiext net
Have you first established the connection between the Router and the Extender?
If so, have you connected e.g. a laptop to the Extender?
So if your WLAN networks SSID is NETGEAR, the WLAN network of the Extender is NETGEAR_EXT and you have to connect the laptop to NETGEAR_EXT.
Then you have to open your favorit internet browser and have to type in www.mywifiext.net, which I guess is a buildin Setup-Assistant.If this doesn't work, make sure, your laptop is configured, to get an ip address automatically via DHCP.
Or read http://kb.netgear.com/app/answers/detail/a_id/20912
I purchased a Netgear Universal Wifi Extender for my ipad, i've set it on on the ipad and it says its connected and evreything and the little correction mark comes up on the ipad showing connected. the...
Extender means it extends the existing Wifi or network. So the iPad now connects fine to the extender, but the extender needs to connect to the existing network either via Wifi or cable. You need to open from the iPad the admin page of the extender and find the connection details there to your existing network.
45helpful
2answers
Top NetGear Computers & Internet Experts
Mike
Donivan Wise
Narseman
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
