SOURCE: 925 Plantronics will not pair with cell phone.
You are holding down the main button too long. When it flashes blue and red it is now in pairing mode. To turn on the headset hold down the main button until you see the blue light come on, then let go. If you hold it any longer this is when it goes into pairing mode.
SOURCE: Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
SOURCE: when trying to pair my
Good luck from Headsets Direct - 800-914-7996.
SOURCE: Plantronics Voyager Pro bluetooth headset
You want to turn off the power to your headset and turn off your phone.
Remove for 30 seconds the battery from the phone and reconnect. Then
follow the pairing instructions found on pages 4-5 in this link
for the Plantronics Voyager Pro+.
Good luck from Headsets Direct!
SOURCE: my plantronics voyager pro won't
Go into your Motorola Q's phone menu and delete the VoyagerPro, then
turn that phone off. Now try relinking the VoyagerPro to your new phone.
Plantronics Voyager Pro+ User's Guide
