Question about Thermador MBBS Microwave Oven
Thermador MBBS/01 My microwave spark like frame come out from right side where is thin foil cover when using. Please help Thank you.
Posted by kam1111 on
  • graceba Feb 07, 2008
    I have the same problem with my Thermador MBBS/ 01. It started after the appliance was only 14 months old. The repair guy replaced the wave cover but abou 8 months later, it is happening again. He left me with an additional wave cover so I took off the one he installed and noticed that it looks like the paint has burnt off under the cover. This shouldn't happen. I think it has something to do with the internals of the microwave.
  • Anonymous Jan 05, 2009
    Hello, my Thermadore is just 18 months old and does the exact same thing.
    Is this a manufacturer problem or what?
    Anyway, thanks to this forum, I guess I can try to fix it myself and I'm very grateful for that!
    THAKS!
William Miller
  • Thermador Master
  • 9,179 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
Posted on Nov 28, 2007
Is there a replacement microwave for the Thermador MBBS/01
The MBBS sereis was replaced by the MBES series.
Specs are here.
Nov 27, 2012 | Thermador MBBS Microwave Oven
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
I need to replace the waveguide in my Thermador MBBS / 01 microwave.
Waveguide "cover"I presume? The waveguide is part of the chassis and cannot be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 26, 2011 | Thermador MBBS Microwave Oven
Thermador built in microwave turns on but wont heat worked great this morning. model# MBBS/01 serial# FD8602
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 02, 2011 | Thermador MBBS Microwave Oven
Mbbs/01 microwave makes noise when turned on and doesn't get hot. Is it fixable or need to be replaced?
Sorry to read about your problem, I hope this helps you out.
yes they are all fixable..just depends on repair cost
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Thermador MBBS Microwave Oven
Is there a replacement microwave for thermador MBBS that fits MT30S trim kit?
Thermador doesn't make one, but we found the GE JEB1860SM1SS from Home Depot fit perfectly. For only $259. The repair to fix our Thermador was $618. It was only 5 years old. I couldn't believe it already went out. I won't be buying anymore Thermador appliances.
Dec 20, 2009 | Thermador MBBS Microwave Oven
TURNTABLE INOP on mbbs/01 thermador microwave
easy...first thought it was a program glitch. turntable could be turned off manually. nope ...just a bad motor needed replacement
Sep 14, 2009 | Thermador MBBS Microwave Oven
Sparks aplenty!
This is usually just due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
If so, please double-check your model number on the tag so we can help you better.
Jan 05, 2009 | Thermador MBBS Microwave Oven
Smoke Coming from inside of Microwave even when warming for 10 seconds
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Oct 10, 2008 | Thermador MBBS Microwave Oven
Sparks
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
You should be able to order one here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 21, 2008 | Thermador MBBS Microwave Oven
Thermador MBBS Microwave Oven Logo
1,173 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
