Question about Xerox Office Equipment & Supplies
Xerox 7335 workcenter fault code 024-360 - Xerox Workcentre 7345 Printer, Copier, Scanner
Posted by Pintu Kumar on
docukaaf
    Habit-Forming:
  • 38 Answers
There is a problem with mcu. Try reconect mcu plugs
Xerox 7335 workcenter fault code 024-360 - Xerox W - 2_23_2019_4_57_23_am.jpg
Posted on Feb 23, 2019
Terry
  • Xerox Master
  • 11,377 Answers
5 Related Answers
z-roxman
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
Anonymous
SOURCE: learn how to use my scanner on my xerox workcentre xe80
dont know how to scanner
Posted on Dec 08, 2008
Anonymous
  • 3 Answers
SOURCE: I need to know where
PostScript language support is available as an upgrade kit from Xerox - You need to buy it and I was advised it is around the £400 mark.
Posted on Jun 17, 2009
Anonymous
  • 118 Answers
SOURCE: Oce vs. Xerox Recommendation
I can't speak for the OCE model, but I have worked on the WCP 7345 (I'm a trained Xerox tech), and I find them to be very reliable when it comes to recommended repair cycles and overall wear-and-tear of consumable parts.
Posted on Aug 21, 2009
Testimonial: "Thanks, that's the kind of advice I'm looking for. "
maryjane321
SOURCE: my Workcentre 7345 has a Fault Code 012-350
Make sure the cable from the Finisher is connected to the main section of the machine.
Posted on Feb 16, 2011
Xerox 7345 error code009-936 has been received. Please send the solving process.
Return to Search Results
Solutions for : Fault Code 009-936: More Than One Consumable is End of Life Fault Related Fault Code: 009-936 Solutions ranked by relevance:
  1. Make Sure All Highlighted Supplies Are Replaced
Have you found what you are looking for? Yes
Not Yet
Please Help
Dec 17, 2015 | Xerox Workcentre 7345 Printer, Copier,...
Xerox 7328 error code 026-717
Make sure the DNS info is properly configured.
http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html
Jun 23, 2012 | Xerox Workcentre 5225 / Copier, With...
How do I clear fault code 016-311 for workcentre 7345
That error indicates the scanner is not installed. Check the connection from the scanner to the main ess board and reseat if necessary. If cable is damaged, replace with part number 117K38440.
http://www.iteminconline.com/117k38440_117k38440-xerox-workcentre-7425-iit-controller-cable.htm
Mar 12, 2012 | Xerox Workcentre 7345 Printer, Copier,...
79 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
