Question about Yamaha Audio Players & Recorders
My yamaha HTR-5660 is stuck on 6ch input. I cant get ride of it. Even left the darn thing unplugged for a week.
Posted on Oct 17, 2022
1. To restore your amp to the Factory original standards:
Please press one of the component selector buttons other than
AMP(TUNER).
Press both VOLUME buttons (u/d) at the same time for about four
seconds. The indicator flashes twice.
Enter the code number "9990". Make sure that the indicator
flashes twice.
2, To return to the factory-set codes in each mode:
Press one of the component selector buttons which corresponds to the component to be returned to the factory-set code.
Enter the code number "0000". Make sure that the indicator
flashes twice.
The following codes are factory set.
Component selector button Code
TV 0101
CBL/SAT 0006
VCR 0002
DVD/LD 0008
CD 0005
TAPE/MD 0024
It is recommended that you should write all the code numbers you have set on the table above.
Posted on Feb 24, 2019
SOURCE: I'm getting no sound from my htr-5450 reciever
Check the "speaker selector" on the front panel. Make sure A, B, or both are lit up. Also, make sure the "6 ch input" is"off" it's a button right below the volume knob on the right If it's still not working, post a comment and I'll help you troubleshoot further. Hope this helps
Posted on Jul 01, 2009
SOURCE: factory settings
I only found this on the manual
if the power is cut for more
than one week, the parameter value you edited will
return to the factory setting."
Posted on May 13, 2009
SOURCE: how do i reset my yamaha dx 100 back to original factory settings
yamaha dx100 reset. Press voice switches 1 and 2 while turning power switch on. Display will say test entry?. press the plus/yes button. This will reinitialize all memory to factory settings. Also the lithium ram backup battery voltage will be displayed as check level with a number representing the battery voltage. The number will be 10 times the actual battery voltage. A new battery will display 33 representing 3.3 volts. If your reading is below 22 then your battery is shot and will need replacing and if you turn the unit off it will probably get a scrambled memory again.
Posted on Sep 23, 2009
