Question about Panasonic Lands Phones
Panasonic 6.0 has an arrow and symbol above caller list and as a result list does not work ?
Posted by Ray Thornton on
1 Related Answer
Anonymous
  • 2600 Answers
SOURCE: panasonic toughbook cf-w7--cannot get the symbols
It sounds like your computer is set up for the United Kingdom and not The United States....lol enough to drive ya crazy isn't it. Not to fear, this is how you change it.
Go to start > Settings > Control Panel > Regional and Language Options > Now here we will take our time and go through all the tabs because there are different settings that have to be changed and when we are done, re-boot the system and you are all set. First tab to click on is "Regional Options" go to the bottom and change your location to "United States". Hit apply after each change, dont re-boot until we are done with all the changes. Now in the upper window, change the standards and formats to (english) United States. Now click on the language tab, on the settings tab, change the input to language to English-United States. In the installed services window below that make sure that english-United States is added and you can delete the United Kingdon if it is there. click apply and ok and you're done with that tab. Now move over to the advanced tab and select English (United States) and hit apply...do not worry about the window under that...code page conversion, just reboot and enjoy an American Keyboard. Good Luck, ParrotHead PC Repair
Posted on Sep 05, 2009
Testimonial: "Thanks"
HOW DO I SAVE AN INCOMING NUMBER ON KX-TG6812e
Storing a number in the phone book with the KX-TG6812 from the Caller ID list is shown in the manual. WIth all handsets in standby mode, press the Down/Caller List button on the navigator key circle on one handset. Press the down or up arrows to navigate to the number that you want to add to the phone book. Press the right soft key (the LCD screen above the button should be displaying a rectangle with 6 squares). Use the Up/Down arrows to highlight Save CID. Press OK. Use the Up/Down arrows to select Phonebook and press OK. Enter the name of the caller (up to 16 characters). Press the appropriate number key multiple times to display the desired character. Use the * key to switch from upper or lower case. Press the left or right arrows to go to add the next character in the name. If you need to use one of the different character tables, press R/Eco (below the # symbol). Press OK when finished. Press the Call End/Off button to exit the menu.
The manual is available on the product page: https://www.panasonic.com/africa/consumer/telephones-home-security/telephone/cordless/kx-tg6812.html . Scroll down to the bottom of the page or click on the Support link. The direct link to the manual is currently http://www.panasonic.ae/EN/Manuals/KX-TG6812.pdf . You need the information from page 35 to store the number and page 21 to add the caller name to the entry. See page 45 for the extended character tables and the character/number tables.
I hope this helps.
Jul 08, 2018 | Lands Phones
I have a Panasonic telephone model kxtgea20, which does not display the caller id, how can i correct this?
When you are looking at the Caller ID list, hit the right arrow and the number will appear.
Mar 17, 2018 | Panasonic Lands Phones
I need to know how to unblock a caller on a Panasonic cordlesss phone .... KX-TGE263
From a handset with the phone in standby, press the following keys: Menu # 2 1 7 . Then use the up/down arrows to select Block a specific number and press Select. Use the arrow keys to select the number and then use the soft key to choose Erase. Use the up/down arrows to highlight Yes and then press Select again. Press Off to exit the menu system. This is shown on page 47 in the manual.
If you wish to go through the menus using the up/down arrow keys only, go to Settings and press Select. Look for the Call Block item and then press Select. Then select your number and Erase as above.
The manual is available from Panasonic. The current direct link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tge260_mul_om.pdf .
I hope this helps.
Apr 06, 2017 | Panasonic Lands Phones
How do i reset the answering machine on my cordless phones at home
My panasonic handsets have a row of black buttons above the number keys and answer and end call buttons. The screen above these shows little pictographs of what the buttons will do, the left has a book which is the phone numbers stored on the hand set, the middle one has a picture of 2 rows of 3 white dots, this is the button to press once. You then get options of Caller list, Answer system, Handset setup and Base unit set up. Use the big central button with arrows to scroll through the list, please note that the base unit is off screen initially. Select Answer system by pressing the black button below ok. This givs a new list of options, Play new message, play all messages, Record Greating, Answer on, Answer off, PLay greating, Erase message and settings. Slect the required option by pressing black button below the on screen OK. The left hand button will take you back a step, but if you don't press anything after a short time hand set returns to normal. Hope this helps
Sep 06, 2016 | Panasonic Lands Phones
The Base says new cid:34. How do I get it back where it was. I tried to get a number that rang and it changed the settings
Julie,
Sounds like 34 is the # of calls that came in on the caller ID (CID) lis
To open the Caller ID list, press the little phone handset symbol (it looks like a big "C" then ID next to it) on the right side of the 4-way button (it toggles 4 ways, so press to the right side to get the Caller ID list).
The phone will show the number of new calls (or Caller ID records) and the total number of stored CID records. Use the "up" arrow and "down" arrow to scroll through the list.
It looks like you have the Uniden DECT 6.0 6035, so I attached the manual in case it helps.
You can set up the answering machine if the voicemail was deactivated by Lifeline (page 38 in manual shows how to set up answering machine). If 4 rings is not enough, you can change the # of rings (page 40) and to use the answering machine/voicemail, see page 42 in manual.
Uniden 6035 1 Owner Manual
Nov 03, 2015 | Uniden DECT 6.0 Cordless Phone ID
Describe your cidco cw99 caller id+ user manual Problem I want to delete old data, set all to 0 calls. I don't have a user manual ! Thanks.
Hi drkossvt,
The way to erase all calls on the cidco cw99 caller ID is to arrow into the caller ID list and hold the Delete button for about 6 seconds. The screen will display "- NO CALLS -"
Note: it does not matter which Caller ID entry you arrow to before you hold the Delete button. This also works if you are on the "- END OF LIST -" screen.
If you want to delete a single call, arrow to that call and press the Delete button twice.
Feb 12, 2011 | Home Security
Panasonic KX-TG2235B KXTG2235 Cordless Speakerphone with Talking Caller ID how to stop it
Press MENU button, scroll to Talk Caller ID by pressing up or down arrow keys, then press Select. Choose off or on by pressing the up or down arrow keys, press Save then press OFF to end
Talking Caller ID is covered on page 14 of the manual. The following link is for a download of the manual in pdf format.
http://service.us.panasonic.com/OPERMANPDF/KXTG2235B.PDF?cm_sp=Support-Operating Instructions-_-Model-KX-TG2235B-_-KX-TG2235B Operating Instructions (English)
Feb 01, 2011 | Panasonic KX-TG2235B KXTG2235 Cordless...
How do I get the Panasonic KX-T7633 to show incoming caller's phone number? Is this a feature the phone automatically has or do I need to contact my telephone provider? Thank You.
You need to have Caller ID enabled by your telephone provider. Most providers charge a fee for the service. (In my area, it is $4.50 to display just the incoming number, $6 for names and numbers or you can get it in a bundle with other services for ~$10. Your prices may vary.)
The incoming calls will be listed in the call log once the service is active. You can clear this information when you are confirming the log information after navigating to the desired item by pressing Clear. You use the left/right arrows to find desired log/directory and then the up/down arrows to select a log.
I hope this helps.
Jan 10, 2011 | Panasonic KX-T7633 Corded Phone
My problem is i had purchased a panasonic 5.8 DIGITAL TALKING CALLER ID I WANT THE TALKING ID TO STOP IMMEDIATEDLY. IT IS ANNOYING THE HECK OUT OF ME
Page 25 of the owners manual says you can turn off talking caller id separately for the handset and base unit. For the handset, press [MENU], scroll to "Talk Caller ID" by pressing the down or up arrows, then press Select, then select "off" or "on", then press Save, then Off.
For the Handset, press [MENU], then scrol to "Initial setting", then press Select. Scroll to "Set base unit", press Select. Scroll to "Talk Caller ID", then press Select. Select "Off" or "On" by pressing up or down arrows.
Jan 13, 2009 | Panasonic KX-TG2336-S Phone
Panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Carl
Dec 05, 2008 | Panasonic KX-T7431 Corded Phone
Lands Phones Logo
96 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
