Question about Tag Heuer Watches
Any idea why Aquaracer Automatic has stopped working? Well looked after daily ware watch. No memorable incidents in last week that can explain sudden issue.
Tag Heuer Aquaracer Automatic, was working fine but after several days of not being worn it needed rewound. When trying to wind in position 1 there is a slight grinding noise and the minute/hour hand turns as if it is in position 3. When trying to wind mb 'shaking' / moving is rotational motion, the second hand goes backward and the minute hand jumps around. Watch is only 1.5 yrs old.
Posted by Stuart on
3 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I own a tag heuer
Yes it is correct as your watch has a counterclockwise crown forward setting direction. This is due to the specificaly layered lever and setting gear construction, so, nothing wrong with your watch.
Do not forget to rate, please.
Posted on Jan 27, 2009
Anonymous
SOURCE: tag heuer link automatic
exact same problem, no one seems to know
Posted on Mar 08, 2010
Hi, I've got a automatic tag aquaracer watch that loses about 4 mins every month (about 4 yrs old). Common problem? Can this be fixed ? Or is it a lemon of a watch? Any advice welcome. Cheers.
If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
Sep 09, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
My WAF2110 will ocassionally lose about 20 mins for no reason,also does this watch have an internal battery.
Automatic watches are spring driven and therefore do not have a battery.
Automatic watches thrive on being used and if you do not wear them sufficiently, they will run down and stop (or perhaps they run slowly before stopping).
Your watch should run for 38 hours before stopping.
Mar 31, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
Battery Charge Life 10 years ago, not being able to afford a real TAG, I purchased a 'replica' Aquaracer Automatic in Bali. I am happy to say that I am now the proud owner of a real Aquaracer Automatic....
If you go to http://ww2.tagheuer.com/_documents/manuals/EI2246_en.pdf
you should arrive at the user manual for a Tag automatic watch which is similar to yours (an Aquaracer).
You will see that they claim 38 hour running when fully wound.
In view of the very small forces involved and the variations that occur in the manufacturing of the mechanism, I don't think that you should be surprised if there is a variation in running time.
If your genuine watch runs for a significantly less time thean they claim, you may have a reason to complain.
May 29, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
Hi, I've owned my aquaracer for 1.5 yrs and it has just started to run slow, I've had to reset it 3 times this week... does this run off a battery?
I think it depends upo which model you have but the web site does not discuss this.
Generally, if it says "automatic" then it is spring driven (does it stop if you don't wear if for a few days?).
If it keeps going, when not worn then i is a battery driven type.
You can see the range of models on their web site http://www.tagheuer.com/the-collection/aquaracer/man/leonardo-dicaprio-ltd-edition/index.lbl?w=WAJ2116.FT6022. and you may be able identify yours from their list.
May 11, 2010 | Tag Heuer AquaracerWAF1110.BA0800 watch
Hi.i just boughta tag heuer grand carrera xx007344.immediately i got home,it stopped working.so,after abit of winding it starta working.but if i just drop for a minute or two,it stops working.even when...
Automatic watches will generally run for 2-3 days before the spring is fully unwound, so you are likely to have bought the watch in the unwound condition.
It can be wound by gently shaking the watch from side to side (for about 100-200 times). This should give it sufficent engergy to operate and thereafter normal use will keep it wound up.
If it stops working when the watch is rotated out of the face up position, then it may be that the watch is faulty. (If the watch has been dropped in transit, it may have been damaged).
If normal operation is not achieved, then send it back to get it repaired under warranty.
May 04, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
Second hand not sweeping but jumps at 5 secs intervals. Appears to be keeping accurate time.
When the second hand moves in short jumps rather than a smooth sweep or a second-by-second hop, it means that the battery is about to run out. Usually, with a week or two the watch will stop working altogether. You should go and have it changed as soon as possible.
Aug 02, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
My tag heuer aquaracer has a problem: the second hand stops and then speeds up really quickly for about 5 seconds. any idea why/how to fix it?
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4-5 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Mar 11, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag automatic watch = stopped working
Stop shaking it!
You could try wearing it and it should wind itself with your body motion or...
your could manually wind it (setting 1)
Jan 22, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
I have a question for tag heuer 2000 exclusive automatic
The battery power supply will last for two years and if you don't used nothing its happen to your watch..
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 10, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
My Aquaracer Automatic doesn't keep exact time
you bought a automatic watch, they are a quality time piece, not an acurate time piece. if you want acuacy buy a cheap quartz watch.
Apr 07, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
Watches Logo
93 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
