Question about Hitachi Televison & Video
Have a Hitachi Ultraviolet 60 inch TV, I cannot channel to show up on my screen, just stop working. My Xbox works on it and Netflix too, what could be the problem
Posted by Sonya Torraville on
Stephen Miller
  • Hitachi Master
  • 1,645 Answers
5 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Posted on Jan 07, 2008
Ajkill
Anand Kumar
  • 2035 Answers
SOURCE: Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Posted on Aug 01, 2008
Anonymous
  • 39 Answers
SOURCE: Poor Signal Strength!
you can buy a cantenna... http://www.cantenna.com/ or you can get a delicious can of pringles and go here http://www.oreillynet.com/cs/weblog/view/wlg/448...good luck to you
Posted on Feb 05, 2009
pabloloco
Paul Sager
  • 2335 Answers
SOURCE: SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Posted on Dec 26, 2009
lp60
SOURCE: connect hp laptop to tv to watch Netflix downloaded movies
how do i hook up my hitachi tv to my hp laptop to get netflix?
Posted on Feb 12, 2011
When I click to open Netflix from Roku, there is no title pictures showing in the little boxes. There are only little pictures of a TV. What happened
Roku
  1. Press the Home button to navigate to the Roku home screen.
  2. Select Settings.
  3. Select Netflix Settings.
  4. Select Deactivate this player from my Netflix account.
  5. Select Yes. The device is now deactivated.
  6. Select Netflix from the home screen and follow the prompts to reactivate the app.
  7. Sign in to your account and try Netflix again.
All other Roku models
  2. Highlight the Netflix app and press the star key on the remote.
  3. Select Remove channel.
  4. Select Remove channel again to confirm.
  5. From the home screen, select Streaming Channels.
  6. Select Movies & TV.
  7. Select Netflix.
  8. Select Add Channel.
  9. Select Go to channel.
  10. Sign in to your account and try Netflix again.
Sep 25, 2017 | Televison & Video
I have a 60 inch Vizio smart tv. I can't connect with Netflix. I can't find my Wifi on the connectivity screen.
Do you know for sure your WiFi is working? If it is, is your TV within range of the signal?
May 05, 2017 | Vizio Televison & Video
Will a roku work with netflix
Netflix Activation with Roku devices
  • Make sure that you enter Roku activate devices and also incorporated with the 5.1 audio options.
  • These 5.1 audio options are required for streaming of high quality contents.
  • So ensure your Roku device comes with these 5.1 audio options to enjoy high quality screening.
  • All the devices have Subtitles and captions as a default options.
  • Netflix avail users with Parental controls options and they can set their own Individual Profiles.
  • For Roku 1 model Go to Home screen > Select Netflix. You can visit channel store and your preferred Movies and TV shows are selected from there. Once you selected your preferences choose Netflix and add channel option is clicked to add your favourite shows.
  • In case of other Roku models, Go to Home screen > select Netflix. Go to channel streamed and then select preferred Movies and TV shows. Select the SignIn option from home screen activate Netflix in Roku to stream your preferred contents.
Signing out of Roku
Make sure that you enter Roku activate devices and navigate to Roku Home menu by pressing the home button. Select the Setting and choose Netflix settings from the menus. Select Deactivate the player from the Netflix account and chose the option yes now your Roku device will be deactivated.
Jan 22, 2017 | Roku Televison & Video
Netflix has stopped streaming videos
Same thing happened with my Roku. I went into menu and deleted my Netflix channel. I went to Netflix.com and re-registered my account as if I was a new customer. I turned off Roku and restarted 30 min or so later. I then added Netflix to my channel choices. It worked. Good luck.
May 03, 2014 | NetGear NeoTV NTV200
The tv froze up while watching netflix and won't turn off or do anything
Sounds like the CPU froze. Unplug set from power completely, then plug back in, should work. If not then the problem will have to be solved by a repair technician.
Mar 12, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
Connect hp laptop to tv to watch Netflix downloaded movies
Jul 23, 2010 | Hitachi 51F59 51" HDTV Projection...
3 inch blank space at top and bottom of 50 inch projection hitachi ultra vision
Good Day, richardyoung;
Lack of vertical reflection? Does this happen on all channels? Can you change channels and the picture size changes? Are you receiving a HD signal? Have you tried changing the format?
I hate to ask you all these questions but I need to understand your concern completely. If you answered some of questions above yes / no; your TV might be okay. But try them.
Good Luck, big IRISH.
Jul 29, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
