Question about Fujitsu Heating & Cooling
My Fujitsu model AOTG45LATL has the error code 97, how can I fix it, thanks ?
My fujitsu was running, my house has 2 zones. When I pressed to run 2 zones, then the light start/stop on air conditioner blinking and the air conditioner stopped, it displays error code 97, I tried press start/stop again it happened the same, thanks.
Posted by Michael Le on
5 Related Answers
Anonymous
  • 145 Answers
SOURCE: Error code 1 2
I found this list of codes
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Posted on Feb 12, 2008
TpUg
  • 25 Answers
SOURCE: KItchen Aid Dishwasher KUDI01FL Stopped Running and Will not Start
try the reset button sequence i posted in the other question..
Posted on Jan 24, 2009
Anonymous
  • 10 Answers
SOURCE: I have a model AR DL10 remote for a Fujitsu air
After changing the batteries you have to depress the RST button and if the remote has the abcd slide switch ensure it is set to A.
Posted on Jul 15, 2010
Testimonial: "THANKS"
Anonymous
  • 6 Answers
SOURCE: Ihave a fujitsu air conditioner
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Posted on Aug 13, 2010
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Mitsubishi model Wt-46807 Power shuts
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Oct 16, 2010
Error code "L"
Is the code display L-6? This error code describes US Sensor Alarm.
You may perform the following steps or may ask your local Fujitsu scanner expert for the disgnosys and replacement of faulty part.
1. Does the same symptom occur after turning OFF and ON the scanner? To check, press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Check the US Sensor operation by conducting Maintenance mode to see if the US sensor works properly. If the error still occurs, confirm that the sensor cable is correctly connected. And then replace the US Sensor FX and US Sensor RV.
Thanks & regards,
ScanCare
Aug 05, 2013 | Fujitsu fi-6130 Flatbed Scanner
Fujitsu aou30clx compressor location detection error
You must turn off of the power for 10 minutes. Then open the front of the indoor unit and push the emergency button for 10 seconds. The compressor will unlocked.
Apr 18, 2013 | Fujitsu 30CLX HALCYON Wall Mounted Mini...
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
I have a fujitsu invertor AOT54LJBYL and the key pad comes up with EEE
When EE:EE is displayed on remote control , press "Energy Save" &"Zone Control" buttons simultaneously for longer than 3 secs. The error code will then be displayed on the LCD.After getting error code, please write here to get solution. Thanks.
Feb 04, 2011 | Heating & Cooling
CODE ERROR E.EE
code will then be displayed on the LCD.Thanks.
Jan 15, 2011 | Fujitsu Heating & Cooling
I have a Fujitsu inverter split system,(ASTA18LCC) which the power was removed for a while. Now when you start it up on any mode the red operation light is on briefely, then the green timer light flashers...
To work out what the error code ispress the orange start/stop button on the remote controller so unit operationis stopped.
Then press and hold "energy save" and "zone control" buttonsimultaneously for at least five seconds, the error code will be along thelines of En:nn where the "En:" is the error code and the":nn" indicates the indoor unit address if there are multiple indoorunits connected to the one controller. If the upper vertical bar on the capitalE is missing so it looks maybe like a 2 or something don't worry for somereasons they just do that
Some common error codes are:
E0 Communication error between indoor unit and wired remote control, check ifthere is 12VDC between terminal 1 + 3 at remote control and 8-9VDC pulsatingbetween terminal 2 + 3. If DC volts out of Indoor pcb is below about 11.6VDC itwill cause this error, the problem is normally dry capacitors in the 12 VDCpower supply section. This model has two power supply sections on indoor pcb.
E1 Communication error between indoor unit and outdoor unit,
EF Discharge temperature abnormal
Is it helpful?
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
How do I run a Fujitsu PC headless?
while booting press F2 to enter to bios setup.
in the main tab go to Boot Features.
the first point in Boot Features is POET Errors will be "Halt On All Errors" then you have to change it to "No halt On Any Errors"
May 13, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
CMOS settings on startup
If u mean by the internal battery ..the icon battery which placed on the mainboard .. so u just need to prss F2 to adjust the current date and time .. and to get stable Download the bios update from fujitsu.com .
good luck
Nov 10, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu 4860c scanner error
There are 2 sensors on the background unit(Front) SF1.5 and SF 2
Both sensors look like black boxes. SF2 is nearest the reading glass and SF1.5 is below it. Make sure both are clean. There are also tests you can run in test mode to recalibrate the sensors, if that doesn't work you have to replace it.
Apr 24, 2008 | Fujitsu FI-4860C2
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
Dan Webster
Dan Webster
jdthefixer
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
