Question about Philips Magnavox 51MP392H Rear Projection Television
Tv problems I have a Magnavox 51" rear projection screen tv that when I turn it on the screen comes on and about 10 to 15 seconds the screen will shut off but I stll have the sound so the tv still has power and is still on, but no picture and it does it if either hooked to a dvd player or cable.
Posted by behee on
  • bmoore62 Apr 06, 2008
    I have an AKAI 42" television that seems to take forever to warm up. When I turn it on, I get no picture, but rather a fuzz. I have to leave it like that for at least 15-20 minutes, shut it off, wait a few seconds, then turn it back on. Sometimes that will solve the problem, but even then the picture sometimes will disappear and I get a fuzzy background. Any help?
  • Anonymous Apr 12, 2008
    I have a similar problem: I switch theTV on and after 10 seconds it goes off, all by itself. Then I switch it on again, the same happens and so on...
    Now I cannot watch TV anymore and my fingers hurt from the constant switching on.
Anonymous
I have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Posted on Mar 29, 2008
When i turn the tv on, it's on for a second for the screen to turn on, then it shuts off.
Do you have excessive drive lines on screen before it shuts off?
If so then you need to adjust the screen controls to your Tubes.
Jul 10, 2010 | Sony KP-51HW40 51" Rear Projection...
Power issue
No picture on my Magnavox Big TV RJ8530 S/N 61998120
Aug 06, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Magnavox big screen problem
Its not the bulb.
When it comes on is it real bright?
Did you loose the audio also?
Any other symptoms prior to having this problem?
Aug 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Mute and C on the screen
The TV is in factory or demo mode - turn tv off and unplug it from wall outlet for 30 seconds - turn tv back on after 30 seconds and see if problem goes away. If not, press the (volume -) and (channel -) buttons repeatedly for about 10 seconds to see if "C" will go away. If this fails call 1-888-PHILIPS for further assistance (they do Magnavox also).
May 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox TV will no longer turn on
Does it beep .. or anything? Does the front LED come on?
May 24, 2008 | Philips Magnavox 51MP392H Rear Projection...
Picture and screen
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 02, 2008 | Sony KP-51HW40 51" Rear Projection...
51" Magnavox projection TV
same with mine. Two things that they have to install and they need the whole tv there to fix it and run it for a week. Cost 500.00!!!
Aug 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51" TV Screen
take the broken piece to the hardware store and have a piece of plexiglass cut the same size. thats what we did and it worked really well.
Jan 31, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
148 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
