I have recorded the noise on my cell phone and can text it to anyone that would like to help me.
Some more suggestions from Dell:
https://www.dell.com/support/article/us/en/04/sln145553/how-to-identify-and-resolve-noise-issue-on-dell-laptop-pcs?lang=en
No computer even stated,? why?
sorry I can't hear it!@
a bad fan
a dirty fan clean it.
a bad Hard disk drive HDD , head crash.
or loose parts inside,
or the beeper in side is beeping codes
called POST error BEEP codes. we count them.?
and report them here?
beep beep beep pause , repeats>? code 3.
why not get it repaired in a PC repair shop.?
they can hear it and fix it for sure.
assumes speakers (audio) are quiet.
SOURCE: TEXTING
buy a memory card , change settings to store the message in memory card, and read the whole message.
SOURCE: can i turn off the qnotes feature
Your messages are set to 'word' and you want it set to 'alpha'. If you have your user guide this info is on page 45. Here's how to do that. If this helps plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
You can enter text into your phone using the traditional method of pressing a key several times for each character, or by pressing a key once for each letter while words likely to be the one you want are chosen from a database. You can also enter symbols and numbers into a text field. In screens that require you to enter text, you see the following icons. These icons tell you which text input mode you are using: When you access a screen that requires you to enter text, you start in the mode last used.
To choose a text input mode: 1 At a screen that requires you to enter text, press m. 2 Select the text input mode you want to use. A checkmark appears next to the current mode.
SOURCE: Revving noise-wont record
Turns out the rubber disc grip on the spindle simply needs to be cleaned (using an alcohol wipe). This is the part that holds the disc firm while it's spinning...the noise and failed disc reads comes from this rubber getting dirty and allowing the disc to slip. Total time to fix including disassembly was less than 15 minutes!
SOURCE: Blackberry cell phone got wet; won't work
I cannot remember where i found this but if you look around the internet you may be able to soak it in distilled water and dry it out completely. Apparently the reason for short circuiting the device is due to the mineral itself not the water. I would suggest looking in to that. Hope this helps
SOURCE: how to get rid of suggesting words when texting on pantech jest 2 cell phone
You should be able to go into your text message settings and turn off the feature. Otherwise...go to the store you got it from...have someone there show u.
